PSP 2022 crashes
wizzard
operating_system: Windows 11
PSP 2022 crashes
Post by wizzard »
The start up screen comes up and after a while, PSP crashes. Tried running as Admin as well - no luck. This has suddenly started happening. Have reinstalled twice now without any success.
Jean-Luc
processor: Intel i7_4710 HQ 2_50GHz
Hard_Drive_Capacity: 2 Tb
Corel programs: PSP X7, X9, 2018 to 2023
Re: PSP 2022 crashes
Post by Jean-Luc »
THE PAINTSHOP PRO COOKBOOK
wizzard
Post by wizzard »
Jean-Luc wrote: Sun Aug 07, 2022 11:09 am Try a reset:
https://forum.corel.com/viewtopic.php?t=67616
Cannot do that. Crashes soon after the splash screen. Cannot get to the reset option. Possible to try a command prompt option, if any?
wizzard
Post by wizzard »
Tried Shift + PSP icon click with mouse. No joy.
Kathy_9
Corel programs: PSPX2 ~2022; Painter 2018~22
Post by Kathy_9 »
wizzard wrote: Sun Aug 07, 2022 11:21 am Tried Shift + PSP icon click with mouse. No joy.
When you say "no joy" do you mean the reset didn't help or you didn't get the reset dialog box because sometimes it doesn't come up right away.
Also, sometimes just a restart of the operating system helps.
PSPX9 | PSP2019 | PSP2020 | PSP2021| PSP2022 | PSP2023 & PhotoMirage installed; PSPX | PSPX2 thru PSP2018 owned but not installed
Jean-Luc
Post by Jean-Luc »
wizzard wrote: Sun Aug 07, 2022 10:34 am Have reinstalled twice now without any success.
Did you uninstall it with the appropriate tools?
https://forum.corel.com/viewtopic.php?t=52337
wizzard
Post by wizzard »
Kathy_9 wrote: Sun Aug 07, 2022 4:00 pm
Got the box - still does not work. Still crashes.
wizzard
Post by wizzard »
Jean-Luc wrote: Sun Aug 07, 2022 4:23 pm
Yes. Twice now. Still crashes.
Jean-Luc
Post by Jean-Luc »
Did you install both versions?
Does it crash with 32bit or 64bit version?
Did you update recently the driver of your graphic card?
If so, could you reinstall the previous driver?
If not updated, verify if a new driver is available.
You need also to verify if you have the latest Microsoft Visual C++ Redistributable.
wizzard
Post by wizzard »
Jean-Luc wrote: Sun Aug 07, 2022 9:04 pm Did you install both versions?
Did you install both versions? No - 64bit only
Does it crash with 32bit or 64bit version? - 64 Bit. Tried 32bit and that crashed
Did you update recently the driver of your graphic card?No.
If so, could you reinstall the previous driver?Tried previous one. Still crashes
If not updated, verify if a new driver is available.Using latest Nvidia driver for the card - card is about 18months old
You need also to verify if you have the latest Microsoft Visual C++ Redistributable. Yes. Using latest version
wizzard
Post by wizzard »
Have reinstalled PSP 2022 again. Now the screen goes upto the Welcome screen. Stays there for 2 to 3 seconds and then crashes. very frustrating!
Tried PSP 2023 Trial version - same issue.
Jean-Luc
Post by Jean-Luc »
wizzard wrote: Mon Aug 08, 2022 10:22 am Have reinstalled PSP 2022 again. Now the screen goes upto the Welcome screen. Stays there for 2 to 3 seconds and then crashes. very frustrating!
Disconnected your internet connection and launch the program. PSP is trying to connect to Corel's servers. It could be the culprit.
wizzard
Post by wizzard »
Jean-Luc wrote: Mon Aug 08, 2022 11:52 am
Tried this. Does not work either. Bizzare that it worked all this time but does not now.
Jean-Luc
Post by Jean-Luc »
wizzard wrote: Mon Aug 08, 2022 1:02 pm Tried this. Does not work either. Bizzare that it worked all this time but does not now.
Strange...
Something was modified on your system.
Did you upgrade recently from Windows 10 to 11?
Did you add or remove something (screen, printer, software, ...)?
Did you use CCleaner?
wizzard
Post by wizzard »
Jean-Luc wrote: Mon Aug 08, 2022 3:55 pm
Strange...
Did you upgrade recently from Windows 10 to 11? No. Moved a few months ago when PSP worked.
Did you add or remove something (screen, printer, software, ...)?No
Did you use CCleaner? No. Nothing like that
