PSP 2020 Ultimate.
I had a config which enabled me to see all images in a folder, select one or more and show these on the same display to ba able to edit. Seem to have gone. How do I reconfig, please?
I also had a toolbar at the bottom which showed zoom and other icons. Now gone as well. Help please!
Config problem
- ram: 16gb
- Hard_Drive_Capacity: 1Terrabit
- Monitor/Display Make & Model: twin hp displays
- Corel programs: Pro 2020
- Advisor
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8, 9, X, XI, X2, X8,X9, 2018, 2019
Re: Config problem
Assuming you're in the Complete workspace and not any of the others, on the top menu select View -> Palettes -> Organizer: that should show a view of all images in a folder.
When you drag an image from the organizer it'll open in the editor above. If you need to be able to see all images side by side but they are opening in tabs then in the top menu select Window -> Tabbed Documents to move to Windowed documents mode.
- ram: 16gb
Re: Config problem
To LeviFiction,
Nailed it!
Very many thanks for some clear explanation.
Nailed it!
