layer arrange command does not seem to be working
warrensmith
Post by warrensmith »
Here is a script that was made by recording and was recorded OK with no errors during the recording. Once played back however, the script fails at the layerarrange step with the following error:
The arrange command is not valid in the current program state.
Any suggestions??
Here is the script.
from PSPApp import *
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'PaintShop Pro',
'Host Version': u'24.00'
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Default,
'AutoActionMode': App.Constants.AutoActionMode.Match,
'Version': ((24,0,0),1)
# Vector Selection Update
App.Do( Environment, 'VectorSelectionUpdate', {
'Path': (0,1,[],False),
'Type': App.Constants.ObjectSelection.Select,
'ExecutionMode': App.Constants.ExecutionMode.Silent,
'AutoActionMode': App.Constants.AutoActionMode.Default,
# Magic Wand
App.Do( Environment, 'MagicWand', {
'General': {
'Mode': App.Constants.SelectionOperation.Replace,
'Antialias': False,
'Feather': 0,
'SampleMerged': True
'MatchMode': App.Constants.MatchMode.Color,
'Contiguous': True,
'Point': (202.5,86.5),
'Tolerance': 20,
'AntialiasType': App.Constants.AntialiasType.Outside,
# New Raster Layer
App.Do( Environment, 'NewRasterLayer', {
'General': {
'Opacity': 100,
'Name': u'Raster 3',
'IsVisible': True,
'IsTransparencyLocked': False,
'LinkSet': 0,
'UseHighlight': False,
'PaletteHighlightColor': (255,255,64),
'GroupLink': True,
'BlendMode': App.Constants.BlendMode.Normal
'BlendRanges': {
'BlendRangeGreen': (0,0,255,255,0,0,255,255),
'BlendRangeRed': (0,0,255,255,0,0,255,255),
'BlendRangeBlue': (0,0,255,255,0,0,255,255),
'BlendRangeGrey': (0,0,255,255,0,0,255,255)
'Path': (0,-2,[],False),
# Copy
App.Do( Environment, 'Copy', {
'Path': (0,2,[],False),
# PasteIntoSelection
App.Do( Environment, 'PasteIntoSelection', {
# New Layer Group
App.Do( Environment, 'NewLayerGroup', {
'General': {
'Opacity': 100,
'Name': u'Group 1',
'IsVisible': True,
'LinkSet': 0,
'GroupLink': True,
'BlendRanges': {
'Path': (0,-1,[],False),
# SelectNone
App.Do( Environment, 'SelectNone', {
# Magic Wand
'General': {
'Antialias': False,
'Feather': 0,
'Contiguous': True,
'Point': (478.5,102.5),
'Tolerance': 20,
# New Raster Layer
'General': {
'Opacity': 100,
'Name': u'Raster 4',
'IsVisible': True,
'LinkSet': 0,
'GroupLink': True,
'BlendRanges': {
# Copy
# LayerArrange
App.Do( Environment, 'LayerArrange', {
'Path': (0,1,[1],False),
'MoveAboveSibling': False,
'Path': None,
# LayerStylesCopy
App.Do( Environment, 'LayerStylesCopy', {
'Path': (1,-1,[],False),
# LayerStylesPaste
App.Do( Environment, 'LayerStylesPaste', {
motherboard: Alienware M17xR4
ram: 6 GB
Corel programs: PSP: 8-2023
Re: layer arrange command does not seem to be working
Post by LeviFiction »
There appears to be a small typo/bug in the recording of the LayerArrange command. It has an extra path parameter that tells it to do nothing.
Code: Select all
        'Path': None,
Just remove that one line in the "LayerArrange" command and it should work just fine.
The final version of the "LayerArrange" command should look like this
Code: Select all
    # LayerArrange
warrensmith
Great. Thanks. I'm new to python and PSP scripting. I must have looked at that command for 30 minutes or more the other day trying to figure out why it was not working. I figured the path was wrong somehow and focusing on that, I didn't even see that there was another path command.
Thanks for the catch...
