Clean-Up tool for Video Studio
Pennysteam
processor: Intel I7
Video Card: Atx550
Hard_Drive_Capacity: 2.25tb
Corel programs: Video studio 2018,2019,2020
Re: Clean-Up tool for Video Studio
Post by Pennysteam »
Install of 2020 got stuck, just like on several other posts on here from past version. Can’t install, repair or uninstalled now, repair reboots about 60% in.
Tried manual uninstall but no good.
Looking at this issue in the past, the only way is to use the cleanup tool, but there isn’t one yet for 2020.
glus
motherboard: MSI Z390
processor: Intel i9-9900K
Video Card: NVIDIA GeForce 2060
Monitor/Display Make & Model: Acer X233H
Corel programs: VideoStudio, Pinnacle Studio
Post by glus »
Hi Pennysteam,
Sending you a PM, requesting log files from C:\ProgramData\VideoStudio Log Files\VS2020. We would like a look at these, first Possible the cleanup tool can help, but we won't know until we can dig in a little more.
Telmo
motherboard: Asrock H370M Pro-4
processor: Intel Intel I7 8700 4.6 Ghz
ram: 16 GB DDR4
Video Card: Geforce Gtx 1060 Gigabyte 6GB Windforce
sound_card: C3 Tech
Hard_Drive_Capacity: 1 Tera SSD
Monitor/Display Make & Model: Realtek High Definition Audio
Corel programs: Videostudio 2019 Ultimate
Post by Telmo »
Pennysteam wrote:Install of 2020 got stuck, just like on several other posts on here from past version. Can’t install, repair or uninstalled now, repair reboots about 60% in.
Maybe you should try Revo Uninstaller Pro.
alfons
operating_system: Windows 11
processor: i7 9700
ram: 32GB
Video Card: Gforce GTX1650
sound_card: Sound Blaster Audigy FX
Hard_Drive_Capacity: 1TBSSD+4GB
Monitor/Display Make & Model: HP 24Uh
Corel programs: VS X4-X5-X8-X10-2018-2020-2022
Post by alfons »
Any version for removing Corel Video Studio 2020?
I have just bought the programme and I want to unisntal it and install in a new computer.
I belive I cannot run in two PCs.
Thanks!
Hi alfons
So far Corel have not provided a cleanup tool for 2020, using Program and Features should do the job
We did have a version to test but caused more issues than it fixed
And yes you are correct we can only install VS on one machine, but can re-install when changing machines.
You will be prompted to input your e-mail used to register the program when installing on your new computer.
I would install on the new machine, prove it works then uninstall on the older PC
Trevor
alfons
processor: i7 9700
ram: 32GB
Post by alfons »
Many thanks!!!
JET2020
motherboard: X470 Taichi
processor: Ryzen 7 2700x
Video Card: GTX3060Ti
sound_card: Quad Capture
Hard_Drive_Capacity: 300GB
Monitor/Display Make & Model: EIZO
Corel programs: CorelDRAW,Painter,Paintshop,VideoStudio
Post by JET2020 »
Is there a VideoStudio2020 cleanup tool available yet?
I just want to run the cleanup tool and uninstall it cleanly, but when I hear that it was having so much trouble, I'm worried.
If VideoStudio's standard uninstall system works exactly like a cleanup tool, and can uninstall cleanly, that's fine.
it's a hassle to have to use the cleanup tool after uninstalling it. Is it safe to say that it's such a high performance uninstaller this time around? :(
Telmo
ram: 16 GB DDR4
sound_card: C3 Tech
Post by Telmo »
JET2020 wrote:Hi
Since there is no Cleanup tool for it yet, I used the "Revo Uninstaller Pro".
rcoucou
System_Drive: D
motherboard: Hewlett-Packard 1651 KBC Version 07.25
processor: Hewlett-Packard
ram: 6GB
Video Card: intel HD Graphics Family
sound_card: IDT High Definition Audio CODEC
Hard_Drive_Capacity: 360
Monitor/Display Make & Model: AU Optronics 13,9 Monitor
Post by rcoucou »
bonjour
y a t il une version cleanup pour video studio 2020 ?
en utilisant la procédure de Windows 10
il y a un message erreur
le logiciel est en fonction > donc impossible de continuer la désinstallation
j'ai pourtant vérifier si un process videostudio état en cours , mais rien
la version 2020 pose problème avec d'anciens formats de fichiers vidéo
plantage systématique pendant le rendu
cependant pas de problème pendant la lecture complète de la time line dans videostudio
la version 2018 est bien plus fiable
merci par avance
Rcoucou
processor: AMD Ryzen 9 5900X
ram: 32 GB DDR4
Video Card: AMD RX 6600 XT
Post by Ken Berry »
Our forum rules require all posts to be in English. There is a separate privately run group for French speakers. You could, however, simply use something like Google's translation unit. I speak good French but was surprised at how good the resulting translation was:
"Hello
Is there a cleanup version for video studio 2020?
using Windows 10 procedure
there is an error message
the software is running> therefore impossible to continue the uninstallation
I have yet to check if a videostudio process is in progress, but nothing
2020 version has problem with older video file formats
systematic crash during rendering
however no problem during the complete playback of the time line in videostudio
the 2018 version is much more reliable
Thanks in advance
Rcoucou"
Unfortunately, Corel have still not made a cleanup tool available.
alfons
processor: i7 9700
ram: 32GB
Problem with BCC Boris Title Studio
Post by alfons »
I have a problem with Video Studio 2020. It doesn't work properly and doesn't show all the images, videos etc
I want to completely uninstall the program but I don't know how to leave it completely clean so I can install it from 0!
In fact the problem is with Boris BCC Title Studio, it opens but it doesn't allow me to work with it.
I can't put an image, but everywhere I can see (?) question marks! No allowed to read any of the commands.
Pepi
motherboard: ASUS TUF Z270 MARK 1
processor: Intel i7-7700K
ram: 32GB
Video Card: AMD Radeon RX 5700 XT
Corel programs: VideoStudio 2022; PaintShopPro 2022
Post by Pepi »
Here is the VS 2020 version:
VideoStudio 2020: Instructions to manually remove and reinstall VideoStudio Ultimate 2020
Everybody can think on their own, in how many places user could do an error which breaks their workstation.
One odd question is e.g. why this step is not mentioned at all??
Don't Panic
RobertOZ
motherboard: Asus Prime B550M-A WI-FI AM4 mATX
processor: AMD Ryzen 5 3600 3 6 GHz
Video Card: Asus Geforce GTX 1650 GDDR6 Driver 538 61
Hard_Drive_Capacity: 7 TB
Monitor/Display Make & Model: Philips 32" IPS LED, Samsung 28" 3840x2160 UHD 4K
Corel programs: VS2018/21/22/23 & MS 3D, MCC XL
Post by RobertOZ »
Alfons, before doing a complete uninstall try reinstalling the Bonus Pack, the issue you have has been previously reported, unfortunately Corel have been unable to provide a working VS2020 Cleanup Tool, so a complete uninstall means manually searching your computer and deleting all traces of VS2020
Kelte
Corel programs: Corel VideoStudio 2020
Post by Kelte »
Hello,
Is the clean up tool for Corel Video Studio 2020 ultimate available ?
Looks like I will need it !
Kelte
welcome to the forums,
I have sent you a Private Message
Trevor
