Can VS 2019 do any effects like have text go around an orb or a "moon"
HenryBuck
Post by HenryBuck »
I was wondering if there was a way to have text go around a globe like the way the Universal Logo goes around the Earth?
I would take that effect and take to an existing video of the moon and apply the text to go around it's center, use masks on the side if I have to.
Is there any part of Video Studio or plugins that can do that create that kind of text curved to the surface ?
Thanks in advance.
RobertOZ
Video Card: Radeon HD 5770
Hard_Drive_Capacity: 5.5TB
Re: Can VS 2019 do any effects like have text go around an orb or a "moon"
Post by RobertOZ »
It's a pity Henry, in a previous post you were looking for Boris Graffiti, which can do exactly what you require, if I need Spiral type text or similar I use BG or Corel Motion Studio 3D. Have you checked out all the available filters in BCC Title Studio
HenryBuck
Post by HenryBuck »
Hello mate! Oh does it? Well I couldn't find my old install folders so I said Crikey! :) and ordered the VS 2020 upgrade. I believe Boris is on it.
Would Boris Graffiti give e the chance to create a 3D rotating text to path wrap around an existing video clip?
I would assume that I would need to make masks to hide the parts that go behind the orb?
Thanks again!
RobertOZ
Post by RobertOZ »
But I thought you said that you had the disc set of VS2019, the installer would be on there
Upgrading to VS2020 is not going to resolve your problem, it does not include Boris Graffiti, but BCC Title Studio, and as I do not use BCC do not know if the filter you need is included, a quick look suggests not.
You may be better downloading the TRIAL version of Corel Motion Studio 3D, according to Corel, MS3D will not work with Win 10, but I can assure you that it does, many other MS3D users will confirm.
canuck
Post by canuck »
Motion Studio 3D will definitely do exactly what you want - it can easily create a video similar to the "Universal Studios" logo with the rotating globe and text
HenryBuck
Post by HenryBuck »
@RobertOZ, you are correct but I can't find the "Bonus CD" I found 2 others but noting that says Boris on it. Unless I am not sure which CD has it.
Long story short My SSD C Drive was running out of space because Corel VS 2019 took a lot of it ( Before I upgraded m SSD ). So because I was using the plugins I moved those folders over to another drive ( not remembering to place them back). IO found the folders that have "Boris" in it but I have no idea where they go back to. That being said I thought 2020 would carry the Bonus CD and I could install it again. Just to give it a try, do you know what folders they should be under?
Corel MS #D could I import the 3D text over to VS and use it on a different orb there?
Thanks to you both RobertOZ and canuck.
RobertOZ
Post by RobertOZ »
Henry, why are you looking for the Bonus CD, if you do have a main program disc for VS2019, on the disc should be VideoStudio2019_Installer.exe. It must be there because it will connect to the internet to allow you input your key and register your copy, so that installation can proceed. This will allow you to download the complete program again including The Bonus Features and Contents Packs.
I am not sure that the Bonus Pack would have been included with the main program CD, somewhere in the back of my mind, I have the impression that the Bonus Content was a download and could only be downloaded with an Ultimate Reg key. I am sure Trevor or Ken can clarify that.
With MS3D you can create your text, save and then import into VS2019 as you would any clip, With VSX4 is was possible to directly import from MS3D, but they did not continue with this feature in later versions, don't know why, MS3D is very very stable and can easily create the logo you require
Boris Graffiti was last provided using VS 2018, VS 2019 does not have Graffiti only BCC
The installation files are part of the Bonus Features, this is the package provided when purchasing the Ultimate package which effectively updates the Pro to Ultimate.
The web installer aka stub is 10.960Kb, called VideoStudio_Install.exe, although the names may differ, best way to id is by the files size unless like Roberts version shows 2019
If you do not have the Stub then download from Corel, there is a link via the Updates
https://www.videostudiopro.com/en/suppo ... duct-tab=0
Video Studio -- Trouble shooting -- Download
Running the stub, using your serial number will allow you to download the program installation files again, Download only will allow you to download whilst the program is installed, the list available should have Bonus Features, if not then you have not purchased the Ultimate version
RobertOZ
Post by RobertOZ »
Thanks for clarifying that Trevor, what I thought, Bonus Features only available by download
Hi Robert
I did not say that the Bonus Features are ONLY available via download.
It may be possible that Corel do provide on disc, just that I do not have many disc versions and those I did have were the Pro version.
But it is easy to download providing we have the stub and a suitable serial number.
HenryBuck
Post by HenryBuck »
Thank you both. I am going to try it now. I actually have 2 Corel VideoStudio2019 Licenses ( PC and Laptop ) so I am legit.
I will try that download ( Thank you Trevor ) and see if that takes care of it.
Trevor, Please forgive I am a little confused. The download links above show they were released in 2017?
My version is:
https://imgur.com/AOT6YCY
In essence, would the Boris FX Robert refers to, would that be attainable via
- the link you provided above?
- perhaps the 2020 upgrade 9 ( via related downloads)
- or I'm kind of without.
Thank you,
Hank
lata wrote:
Sat Oct 31, 2020 10:15 am
Henry
Boris Graffiti is not provided with 2019, it has been replaced with BCC.
i have been away from the pc and only now can i try BCC but so far cannot find any option to rotate text around a globe, not that it does not exist.
The 3DTitle Editor does appear to have the globe with spinning text, just tried that but is so slow on my pc its difficult to say if the quality is ok.
Post Updated
This YT video was created using Video Studio by Scubbie one of the forums members
HenryBuck
Post by HenryBuck »
Hello again Trevor and thank you so very much.
I found this, would this do the trick?
Graffiti 6 for Corel Video Studio and Pinnacle Windows 64 - Free form Boris
https://borisfx.com/downloads/boris-gra ... indows-64/
HenryBuck
Post by HenryBuck »
Oops spoke too soon. I am installing and it is asking for Serial. Apologies.
HenryBuck
Post by HenryBuck »
OH Trevor I just saw the video above. Looks great. I suppose it was Boris?
