Ubuntu 18.04.4
AfterShot Pro 3 Version 3.6.0.380 x64
I downloaded 106 RAW image files from my Canon camera into a local directory called "foo." Ran ASP. Selected "foo" from the filesystem tab. 106 thumbnails appear. I edit image settings for the first image, then do a "copy selective image settings" to paste settings to the other 105 images. All 106 thumbnails now display the "edited" flag in the upper right corner. Everything normal so far; exit ASP.
Here's where it gets weird: I run ASP again. I select the "foo" directory from the filesystem tab. 106 thumbnails appear, BUT instead of 106 images, the status display in the lower left now says 200 images. Also 200 previews. All but the first 13 image thumbnails now display a "version" flag (I think that's what that is) in the lower right corner that wasn't there when I exited ASP after editing all of the images. If I exit ASP again, and run ASP again, the status display in the lower left now says 304 images and 304 previews. Every time I exit and re-enter ASP more versions/previews/images are created.
I really hope that someone here knows how to fix this, because it's driving me nuts. If I wasn't a Linux user, I'd switch to Adobe in a flash (ha ha).
Thanks in advance,
- Billw
ASP3 creating extra images/versions I didn't ask for
- System_Drive: N/A
- Corel programs: After Shot Pro 3
- System_Drive: N/A
- motherboard: ASRock
- processor: AMD FX-4300
- ram: 32 gb
- Hard_Drive_Capacity: 5 tb
Re: ASP3 creating extra images/versions I didn't ask for
1. If you'd spent any time looking around the forum before posting, you'd have realised that this is a known - fixed - issue: viewtopic.php?f=94&t=66171billw wrote:<crickets>
2. "Crickets" is generally as good as it gets here. To all intents and purposes (this bug fix being an uncharacteristic exception) ASP is abandonware.
