VIDEOSTUDIO X8 v2-THE MISSING INSTALL/GETTING STARTED MANUAL
canuck
Re: VIDEOSTUDIO X8 v2-THE MISSING INSTALL/GETTING STARTED MA
Post by canuck »
trailryder42 wrote:I have the DVD disc version. I see no "1main.exe" file that the tutorial says needs to be installed first.
I show VSUltimate64.msi and Setup.msi
And what are these VSClassic64.msi, Share64.msi, PreinstallIPM.msi, IPM_VS_Pro64.msi
Thanks for any info.
This Tutorial (not an official one from Corel) applies to the downloaded files and not the DVD.
Are there not any instructions that come with your DVD package?
You should navigate to the DVD and select the "setup.exe" file just like for any other installation from a DVD>
cdoughertycd
motherboard: ASUS PHTD DELUXE
processor: 4 Core 2.93 gigahertz Intel Xeon
ram: 36 GB
Video Card: AMD Radeon HD 7700 Series
sound_card: AMD HD Audio
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Samsung S24B300
Post by cdoughertycd »
Thanks Tanguero for all your work. Wish I had read it first before I did the X8 Ultimate download this afternoon. I got message "newer version of Quicktime is installed, can't finish install". Tried the install twice, no luck, then called sales support who sent me e-mail with same download files, tried that but no luck, each try involving uninstalling X8 and reinstalling. Finally decided to uninstall my Quicktime 7 version and it worked. Took about 2 hours to get this done with the uninstalls and installs.
Then it took three tries to get the Contents exe to download.
Thanks again for all your info and to everyone else here.
Candy Dougherty
tanguero
Post by tanguero »
Yes, indeed, the tutorial applies to the downloaded version only, at least as far as the installation procedure goes, and I will add that observation. As canuck mentioned, probably executing setup.msi is the way to go (though technically you should see what the autorun.inf files says and run that, though more likely than not, it will be setup.msi possibly with some undocumented flags). I would assume that the setup routine then prompts you as to what you want to install and then runs the remaining files for you.
However, if someone can
- Confirm this (that Setup.msi is all you have to run) and briefly describe what happens after that;
- Describe what each of the other .msi files above are and confirm that they are invoked by setup.msi (or if in fact they have to be run separately);
- Describe where to find the 32-bit versions of these files (perhaps on another DVD) and what the corresponding names are;
I'll then include a section in the tutorial on installing from boxed DVD.
BrianCee
Post by BrianCee »
All the DVD versions I ever bought self started the installation as soon as the programme DVD was inserted in the computer drive - the bonus content DVD when inserted gave you a menu asking what you wanted to install.
tanguero
Post by tanguero »
That's because you have Autorun enabled for your DVD drives and it runs whatever is in the autorun.inf file, as I mentioned earlier. I have it turned off (a) primarily for security reasons (b) I might just want to browse the CD/DVD and don't want a program to start every time I insert a DVD.
trailryder42
motherboard: Gigabyte GA-890FXA-UD5
processor: AMD Phenom II x4 965 3.7Ghz.
Video Card: Nvidia GTX 560Ti
sound_card: On Board Realtek ALC889
Hard_Drive_Capacity: 256GB+3TB
Monitor/Display Make & Model: Samsung Syncmaster 941BW
Post by trailryder42 »
tanguero wrote:That's because you have Autorun enabled for your DVD drives and it runs whatever is in the autorun.inf file, as I mentioned earlier. I have it turned off (a) primarily for security reasons (b) I might just want to browse the CD/DVD and don't want a program to start every time I insert a DVD.
That's the way my computer is setup. Browsing the DVD, I came across more than one setup file, hence the questions.
Thanks for the replies.
o0spyder0o
motherboard: Asus P8z68 Gen 3
processor: Intel I7 2700k
ram: 12 gb
Video Card: Asus GTX 970 4gb ram
sound_card: Realtek HD audio
Hard_Drive_Capacity: 1tb
Monitor/Display Make & Model: Asus VE248
Corel programs: VS Ultimate X7/X8/X10 : PSP Pro X9
Post by o0spyder0o »
That was interesting that you mentione dthe bluray plugin is not in X8. If I buy X8 and I already have X7, do I lose that functionality or retain it because I have X7 with it included?
That's a weird thing to do with an 'upgrade'.
BrianCee
Post by BrianCee »
If you buy X8 and do not buy the bluray disc plug-in for it you will need to create the required files in X8 - save them - then shut down X8 and open X7 import the files and then burn a bluray disc from within X7 - it is not a seemless integration
if you are burning a number of bluray discs seems a lot of hassle - why not just buy the bluray disc plugin for X8 when you buy X8 - it's less than $10
Post by Ken Berry »
Brian said:
...you will need to create the required files in X8 - save them - then shut down X8 and open X7 import the files and then burn a bluray disc from within X7
Just a slight, but important addition to that. You need to save them in X7 format. X7 cannot open files created in X8 format. But X8 allows you to save projects in X8, X7 and X6 formats.
Radim
Post by Radim »
To make it complete - links for Video Studio X8 Free Content - http://paintshop.php5.sk/video-studio-x8/
Kenneth Evans
motherboard: Lenovo P70
processor: Intel Xenon CPU E3-1505M v5 2.80GHz
Video Card: NVIDIA Quadro M4000M
sound_card: Realtek and NVIDIA High Definition Audio
Monitor/Display Make & Model: Lenovo P70, Cintiq 24HD
Corel programs: Painter, Paintshop Pro, Video Studio
Post by Kenneth Evans »
In my case installing X8 removed the Blue-ray option from X7, so this would not have worked (independent of how the projects were saved). I have been told others have not had this problem. However, I know I had the Blu-ray option the week before. It might have been caused by trying to open VS7 while VS8 was running. When I did that, it brought up VS8 instead.
I contacted support, but after 2 weeks (and three separate support incidents) they still have no viable way to remedy that. The last suggestion was to uninstall both VS7 and VS8, install VS8, then install VS7. I am not planning to do that. I purchased the plug-in anyway, as soon as I found out VS8 did not have it. It would be nice to have Blu-ray in VS7 but not worth the hassle. This may be relevant, however, if you are trying to avoid buying the plug-in.
Last edited by Kenneth Evans on Mon Dec 07, 2015 10:19 pm, edited 1 time in total.
Kenneth Evans
I purchased the Photo Video Suite X8 (Pro), instead of VideoStudio X8 alone. It presumably contains both PaintShop Pro X8 and VideoStudio Pro X8. It turns out the download links they sent and that appeared on the web page after the purchase did not include a link for VideoStudioX8_2Contents.exe.
It took 2 weeks and 3 support incidents (trying to get another person that might be more helpful) before they gave me a link to it. (The issue was compounded by the problem with losing Blu-ray capability in VS7 after installing VS8, something they never fixed.)
This executable installs a lot of files in Program Files/Corel/VideoStudio X8 Pro and provides a lot of content in the Library. In case you have this problem, are knowledgeable enough to know something is missing, and have come here to fix it, it looks like with enough perseverance you can get the missing file.
asik1
motherboard: H170M-E D3
processor: i5-6600
Video Card: GTX1050
Corel programs: VS-X9.2
Post by asik1 »
I just noticed VSX8 SP3 was out few weeks ago..
http://www.videostudiopro.com/en/support/updates/
larsonreever
System_Drive: M
motherboard: asatcvc
processor: 222
ram: 512 MB
Hard_Drive_Capacity: 32gb
Monitor/Display Make & Model: lg
Corel programs: corel
Post by larsonreever »
if the installation process will have a short subroutine that do this backup, it's only two man/hours of programing.
I understand cost control and I believe the Corel Suite of programs to be a great value. That said, it appears that documentation is not a priority. I don't know about you but the link I get for a VideoStudio Pro X8 Ultimate package is to the VideoStudio Pro X7 program.And in the process, I realized that there are NewBlue audio effects/filters included as well, and both NewBlue and proDAD transitions, so will add pointers to all this in v2.
