Hi there once again, I have downloaded AnyGif5 from a free download.I was told to make a shortcut on the desktop and to put the folder of extracted files into C drive in Corel Program area. Are there any instructions on how to instal and use it.
I have never made any animations before so would like some beginners advice. I do not invisage that I will be doing heaps of it as I believe they take up a lot of space etc.
A friend has made an animated signature for me to use with my VS movies - it was sent as a gif. but I don't know how to go about converting the animation or adding to VS. Can you give me some easy tip for doing this. I have photo impact X3 - the version which did not include it!!
Thanks Rae
Installing Animator into PhotoImpact
- 32bit or 64bit: 32 Bit
- motherboard: Dell Inc.0JC474 800 megahertz
- processor: 2.80 gigahertz Intel Pentium 4
- ram: 2040mb
- Video Card: Inter 82915G GV 910GL Express chipset family
- sound_card: device Instand ld Root Media MS_MMACM
- Hard_Drive_Capacity: 80gb
- Monitor/Display Make & Model: 17" LCD (analog only)
- Advisor
- motherboard: Hewlett-Packard 2AF3 1.0
- processor: 3.40 gigahertz Intel Core i7-4770
- ram: 16GB
- Video Card: NVIDIA GeForce GTX 645
- Hard_Drive_Capacity: 4TB
- Monitor/Display Make & Model: 1-HP 27" IPS, 1-Sanyo 21" TV/Monitor
- Corel programs: VS5,8.9,10-X5,PSP9-X8,CDGS-9,X4,Painter
Re: Installing Animator into PhotoImpact
Hi Rae,
I've copied your post to the GIF Animator & Web Utilities forum. However Ulead produced GIF Animator 5, and Corel's product is Animation Shop 3, not AnyGif. Could you provide a link to where you found AnyGif? GIF Animator 5 is no longer supported by Corel, but you can still find it on the web.. http://download.cnet.com/Ulead-GIF-Anim ... 02057.html
I think the program you downloaded is or was a part of GIMP, which would not be compatible or be able to be used as a plug-in for PhotoImpact.
To use an animated gif in VS, you simply use the File>Insert Media File into the timeline>Insert Video. VS will treat the Animated GIF as a video file. You can also right-click on the timeline, which will provide the same menu choice. If you try to insert your Animated GIF file as a photo then VS will treat it as a still photo and only display the first frame of your animated gif.
