Saving zoomed images in Paint Shop Pro
Postby Stephen47 » Fri Jul 23, 2010 10:12 am
I enlarge an image using "zoom in". But when I view the image after saving it, All I get is the original image. Also the saved version is much smaller size than the original. 782 KB as compared to 2.05 MB in the original.
How do I save the enlarged image and why the size difference?
Stephen47
motherboard: Dell OKD882
processor: Intel Core Duo T2400 1.83GHz
ram: 2GB
Video Card: Mobile Intel 945GM Express chipset Family
sound_card: SigmaTel
Hard_Drive_Capacity: 80GB
Re: Saving zoomed images in Paint Shop Pro
Postby Ken Veal » Fri Jul 23, 2010 11:09 pm
The only way I know is to open up PSPro a second time then do a screen capture of the zoomed image.................Ken
Ken Veal
ram: 32 GB
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2019Ult.PhotoMirage.VS.2019 Ult
Postby Stephen47 » Fri Jul 23, 2010 11:21 pm
That seems highly impractical.
Stephen47
ram: 2GB
Postby LeviFiction » Fri Jul 23, 2010 11:31 pm
Stephen, zooming in refers only to the view of the image. It's like taking a magnifying glass to an image. It doesn't actually change the image itself, only how closely you're looking at it.
Can you tell us what it is you're trying to do?
If you wanted to actually increase the size of the image you would have to go to the image menu and select resize from there. However, it's recommended that you don't upscale an image because it tends to make the image fuzzier.
As for the file size, there's a difference between file size and image size. The image size is how many pixels wide and high the image is. Filesize refers to how much information it takes to make up that image. JPEG compresses the image, throwing away pixels it doesn't feel are needed, to make the file smaller. If the filesize is different it might have to do with the JPEG compression level.
When you go to save a copy of the image make sure to run the optimizer. Go to File->Export->JPG Optimizer. And check the settings. If it's set to a smaller size then that's why. ;D
Postby Stephen47 » Sat Jul 24, 2010 12:59 am
I am making a slide show and some of the pictures need to be bigger. On some of them cropping the picture seems to work but on others it isn't enough enlargement. I tried resizing with unsatisfactory results, cropping and resizing the cropped image didn't work well either.
Stephen47
ram: 2GB
Postby Ken Veal » Sat Jul 24, 2010 9:59 am
Stephen may consider a screen capture highly impractal but it is only a few mouse clicks away and takes seconds to do.I would be very interested to
know if there is any other way of capturing a zoomed image.
Ken Veal
ram: 32 GB
Postby LeviFiction » Sat Jul 24, 2010 2:32 pm
Stephen, resizing to make it larger will always lead to unsatisfactory results. You cannot resize an image larger without distorting it, the pixels needed just don't exist and PSP has to guess at what the new pixels it has to create should look like.
However, I'm curious about which software you're using to do this slide-show. Most programs I'm aware of allow you to zoom in on an image in the slideshow so there's no need to crop and distort an image to zoom in on the location.
Postby Trev Bowden » Sat Jul 24, 2010 3:42 pm
There is when you want to crop to just a tiny bird taken on a 28mm lens from 50 yards and want a HD slide show. I tend to resize down for sideshow and web using a script to get a PAL size of 720 by 528 pixels. suits both
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
sound_card: ATI HDMI Audio.Realtek High Definition
