ASP 3 No visible thumbnail except if I click on each one
- processor: i5 4570 CPU 3.2GHz
- ram: 4GB
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: AOC
- Corel programs: ASP3
I just installed ASP3 on my new PC after having used ASP on my old one. Tried to use it , but no thumbnail is visible. I just have a bunch of squares and they appear only if I click on them. How can I fix it up ?
- System_Drive: Z
- ram: 16 GB
Re: ASP 3 No visible thumbnail except if I click on each one
try: select all - edit - create thumbnails - there are some camera models (Panasonic and others) that have no embedded preview
<CTRL+A> and <ALT+P>
"Under File → Preferences → Import & Cache, there is an option to create
previews during import and file system browsing. Enabling this option
(it is on by default) makes browsing much faster and ensures that the
thumbnails are rendered with the AfterShot settings applied. On the
other hand, it will use most of the machine's resources during preview
generation when a folder is first visited or imported. You should leave
it on unless you are working on a machine with limited power."
hope this helps
hope this helps
regards Hannes
austria
austria
- ram: 4GB
Thanks for your answer. After getting in touch with Corel helpdesk, I loaded version 3.5 and it works OK.
