OpenCL crashes in AfterShot2 (Linux 64 bit)
Bugs & Suggestions
txoni
operating_system: Linux
System_Drive: N/A
Post by txoni »
The application is very unstable when OpenCL is enabled. I even tried pointing it towards the system libopenCL but that didn't help.
Running with Nvidia driver version 331.38, old gpu GeForce 8500GT
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: OpenCL crashes in AfterShot2 (Linux 64 bit)
Post by afx »
What level of OpenCL has been set in the hardware acceleration option in the preferences?
I have not ad crashes with OpenCL but rather nasty image content messups already at standard levels. I had to go to low to make OpenCL not mess up the images.
At the moment I have switched off OpenCL completely in AS2.
cheers
afx
txoni
System_Drive: N/A
Post by txoni »
Thanks for pointing that out. I had lowered it to "low" which did not help but it seems that reducing it to "minimum" as you said, so far it is running stable. Thanks!
