How can i turn the lens correction with the correct EXIF-info on in ASPro2? (3 not tested yet)
I used a profile, but then the initial settings are used, not the actual EXIF-settings.
How to activate Lens Correction for multiple images
Re: How to activate Lens Correction for multiple images
No one? Looks to me a simple question ..
- System_Drive: N/A
- motherboard: asdfasdfasdfasdf
- processor: asdfasdfasdfasdf
- ram: 8GB
- Video Card: asdfasdfasdfasdf
- sound_card: asdfasdfasdfasdf
- Hard_Drive_Capacity: 500G
- Monitor/Display Make & Model: asdfasdfasdfasdf
- Corel programs: AfterShotPro
Hello!
I would be interested in that too.
Do I really have to click on "Reload EXIF" for each photo in the library to have the EXIF reloaded for multiple images?
I use ASP3.
I use ASP3.
Yes, i still found no way to do this in batch / in 1 click all selected pictures.
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- ram: 16GB
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
If you only have one lens, you could of course try to make the lens correction part of your camera or raw defaults. I can't remember (but someone else will) whether the defaults are overwritten during an upgrade, so a good idea to save them outside the ASP3 directory organisation.
If you have several lenses, you would need to muck about with saving the lens specific defaults, and saving them (again, somewhere else so you don't lose them).
HTH
HTH
- System_Drive: N/A
- ram: 16GB
PS, in the case of multiple lenses, you would have to be careful to "import" only the shots applicable to each lens default.
