ASP-3 and Linux
gewb
processor: AMD Ryzen 7 2700X
Video Card: AMD R9-270
Corel programs: 2018, 2020 & 2021 Ult.
Re: ASP-3 and Linux
Post by gewb »
Moved mount point and reistalled ASP3 - all seems to work.
GEWB
Kneops
operating_system: Linux
System_Drive: N/A
motherboard: ASUS P8 Z68
processor: Intel i7 2600
Video Card: nVidia 450
sound_card: onboard
Hard_Drive_Capacity: 14 TB
Monitor/Display Make & Model: Dell U2713H & Spider4
Corel programs: ASP3
Re: ASP-3 and Linux
Post by Kneops »
Good of you to have found a solution :) but ofcourse this is something that still needs to be fixed within ASP.
toby
System_Drive: N/A
Re: ASP-3 and Linux
Post by toby »
I am also getting a segfault crash when trying to open certain folders/images. I identified one of the pictures causing the problem and moved it to a new empty folder with only that picture in it, and ASP3 crashes every time I try to load that folder. I sent a stack trace and core dump to support, but just standard 'clean up' response so far.
dFlyer
System_Drive: N/A
Re: ASP-3 and Linux
Post by dFlyer »
I started this tread several weeks ago and uninstalled ASP3 shortly after installing it to try. Today I took the plunge and paid for the program. I have spent the last 8 hours importing directories by deleting jpg that are miss ID as TIF files. Thank god it was only the jpg. I've imported all the raw files without having to delete any. A guess on my side was I deleted half of my jpg which means I will have to go back and reprocess them some time later. Most of the jpg were from the old bible programs. I'm now going to try and install some plugins as I didn't want to change any problems with them. I would highly recommend Corel do a better job testing software before releasing it as. Right now I can't recommend this program to anyone using linux as it's very unstable, if you have been using Bible or AfterShotPro2.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Kneops
System_Drive: N/A
sound_card: onboard
Re: ASP-3 and Linux
Post by Kneops »
@dflyer, thanks for this update, and now I'm sure I won't upgrade until this issue with Linux is fixed. I'm not going through two years of imported and adjusted images. Unbelievable this hasn't been fixed yet, while there already was an update with new presets. My guess is these presets were already there and they wanted to make a good impression by getting a new update out so quick ;). This issue with the Linux version is serious and should have been fixed within a few days.
dFlyer
System_Drive: N/A
Re: ASP-3 and Linux
Post by dFlyer »
A work around the deleting of a jpg is to open the jpg miss ID as TIF with GIMP and exporting them as jpg. The only problem with this work around is that it's one file at a time. It's easy to delete and recreate a raw to jpg since the raws weren't damaged.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Kneops
System_Drive: N/A
sound_card: onboard
Re: ASP-3 and Linux
Post by Kneops »
Is it still a work around when this concerns a few thousand images? ;)
No, there has to be a solution from Corel, and there will be. I just hope I don't have to wait until Christmas.
dFlyer
System_Drive: N/A
Re: ASP-3 and Linux
Post by dFlyer »
I'm going to post this error message from a file processed with ASP3. I had just created this file with a watermark from a jpg file and saved it with ASP3. Exited ASP3 and restarted the program and the file crashed with this error.
Importing: "/home/gary/Pictures/Family/Tennessee/Izabelle-42516-DSCN3275.jpg"
TIFF Error: /home/gary/Pictures/Family/Tennessee/Izabelle-42516-DSCN3275.jpg "Not a TIFF file, bad magic number 55551 (0xd8ff)"
defaults: "DefaultRendered.xmp"
Segmentation fault (core dumped)
Opened the above file with GIMP and exported as a jpg and now ASP3 loads without crashing. I believe this bug is totally ASP3 ability to identify it's own saves as jpg. Wake up Corel and fix this bug.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Kneops
System_Drive: N/A
sound_card: onboard
Re: ASP-3 and Linux
Post by Kneops »
I so much agree on this. I find it really incomprehensible that there is absolutely no communication about this (and other stuff).
I think there has been one reply, saying that it was pushed to the developers and that we should 'hang tight'. But I've seen this responsive everywhere, with every problem, here on the forum and on the ASP facebook page. It seems to be the current companies motto.
bcelasun
motherboard: ASUS CM6830
processor: Intel Core i5-3450
Monitor/Display Make & Model: Dell 2209WA
Re: ASP-3 and Linux
Post by bcelasun »
I was about to upgrade and just wanted to check the forum if everything was OK for Linux users.
Now, I leave again.
Bulent, a happy LightZone user since the stone age.
AlanGauld
System_Drive: N/A
motherboard: MSI G760 EM
processor: Athlon II X4 640
Video Card: Radeon 3000
sound_card: MSI Onboard
Monitor/Display Make & Model: Asus Ancor
Corel programs: Aftershot Pro 2/3
Re: ASP-3 and Linux
Post by AlanGauld »
Kneops wrote:@Greg
On the ASP Facebook page there are several Linux Mint 17.x users who report constant crashes when trying to open directories.
I use this version myself but haven't installed / bought the upgrade yet, because of these crashes.
Glad to hear I'm not alone. But where is this ASP Facebook page? I'd like to keep an eye out for fixes.
Do I ju7st search for ASP? (I'm not really a Facebook user although I do have an account...)
Kneops
System_Drive: N/A
sound_card: onboard
Re: ASP-3 and Linux
Post by Kneops »
AlanGauld
System_Drive: N/A
Re: ASP-3 and Linux
Post by AlanGauld »
@Kneops - thanks. got it.
grubernd
System_Drive: N/A
Re: ASP-3 and Linux
Post by grubernd »
bcelasun wrote:I was about to upgrade and just wanted to check the forum if everything was OK for Linux users.
Now, I leave again.
thanks for dropping in and letting us know about your time travel from the stone age.
i hope your journey back was more pleasant than your glimpse at the present. :mrgreen:
heidarrafn
Corel programs: AfterShot Pro
Re: ASP-3 and Linux
Post by heidarrafn »
Hello
I managed to tweak AfterShot Pro (ASP-3) to behave better on a HiDPI (4K) display on Ubuntu 16.10 64 bit:
The solution is to use the system provided Qt 5.6.1 instead of the Corel supplied Qt 5.4.0.
The Qt 5.6.1 comes with usable support forHiDPI, see here: http://doc.qt.io/qt-5/highdpi.html
After the install:
sudo rm /opt/AfterShot3(64-bit)/libQt5*
And then in order to run it:
export QT_QPA_PLATFORM_PLUGIN_PATH=/usr/lib/x86_64-linux-gnu/qt5/plugins;
export QT_AUTO_SCREEN_SCALE_FACTOR=1
AfterShot3X64
it is also possible to use
export QT_SCALE_FACTOR=2
instead of
And I also selected "Use smaller fonts..." from Display options.
I have not tested this thoroughly, but it seems to work and is a much better workplace than before - where everything was so tiny, literally unusable.l
