New user but experienced with cataloging.
Is keywording imbedded or is this an additional step ?
If imbedded, where ? Metadata, IPTC, XMP ?
Will ASP pick up the keywording of other programs and from which field?
Thanks.
Dana
Question about ASP cataloging
- motherboard: MSI Z170 A
- processor: I5 6500
- ram: 16GB
- Video Card: Asus GT730
- sound_card: SB Live Extreme audio
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Dell 2208WFP
- Corel programs: PSP X8, VSP 9.5, ASP 1, 2, 3
- Moderator
- System_Drive: N/A
- processor: from atom to quadcore
- Hard_Drive_Capacity: not enough
- Contact:
Re: Question about ASP cataloging
ASP should read all keywords that are inside images or in xmp-files next to the raw-files.
i say "should" because i dont know what camera and fileformat you use.
best is to just use the filesystem tab in ASP to browse to images and see if the keywords pop up in the field.
- ram: 16GB
Thanks.
RAW is .PEF. Previous cataloging was ACDSee Pro 3.
I'm trying to decide if ASP is proprietary xmp or not.
Right now ASP is picking up some keywords from ACDSee but none of the catalog, ACDSee does not pickup the key words of ASP.
Staying with strictly Corel Products, PSP X3 and Photo Paint X4, neither prog is picking up the keywords generated in ASP.
What I'd like ( LOL ) is that keywording be readable across all the programs.
Dana
Dana
- Moderator
- System_Drive: N/A
- Video Card: FirePro 4900
- Monitor/Display Make & Model: NEC PA301w, ColorMunki
- Contact:
Then you need to explicitly write standard XMPs. (Context menu option).thazooo wrote:What I'd like ( LOL ) is that keywording be readable across all the programs.
Thanks to the typical Adobe messup, standard XMPs are named File.XMP which makes it impossible to have two different image file types with individual XMPs. Therefore Bibble, AS and various other programs started to use File.type.xmp to store their settings.
But to facilitate metadata exchange with other programs, AS reads classic XMPs and can be told to write them.
cheers
afx
- System_Drive: Z
- ram: 16 GB
bibble work queues
is the opening of work queues supported?
will there be a feature to write and add to work queues?
hannes
hannes
regards Hannes
austria
austria
- System_Drive: N/A
- ram: 16G
- Monitor/Display Make & Model: iMac 27"
Check on the Bibble forums - there are a bunch of posts on that subject over there
old Bibble user
Hmm is that (old) Bibble user or (old Bibble) user?
- ram: 16GB
Thanks Folks. I now know which direction to take my workflow.
Dana
Dana
- System_Drive: Z
- ram: 16 GB
yes - opening of bibble 4 work queues is working like it used to be on b5
regards Hannes
austria
austria
