Small Pictures for Ebay etc.
Getting it right in the first place is better than fixing it later with software. This discussion forum is for our members to create or provide links to Photography Tutorials. e.g. How to set the controls on the camera. Compose a picture. Lighting, using the camera controls etc.
Post by sjj1805 »
A cheap table top studio!
Of course you could purchase a light tent and lighting or a Table Top Studio:
Image Image
Problem is these things can be expensive, though you can look on Ebay and similar sites for cheap second hand deals. Unless you intend to do a lot of "table top photography" you might have a hard time convincing your spouse/partner of the need to spend the family budget on this equipment.
Here is a very cheap alternative using materials you probably already have, if you don't then I would suspect the only thing you need to buy is a desk lamp. The one I used was fitted with a 40W Tungsten Light Bulb.
Image Image
The only other materials I used were an old white shirt, 3 sturdy boxes, the grill from our oven!
You might also notice a metal weight - that was simply to help keep the creases out of the shirt! Of course you will also need a DSLR camera, a tripod and an optional chair to sit on!
Here are a few pictures of my inexpensive table top studio!
Image Image Image
Having mounted the camera on the tripod I then set the camera so that it had the following initial settings:
Camera = Pentax K100D Super
Lens - the Standard 18-55mm lens that comes with the Camera
Flash - Off (Manual Mode)
Aperture Priority
White Balance = Tungsten
AV Compensation +1.0
F13
The only setting that I had to alter dependant upon what was being photographed was the value of the AV Compensation which I would either move up or down a notch to make the item brighter or darker.
Here are a few pictures taken using this simple and inexpensive set up.
Click a thumbnail to see the full size picture.
Image Image Image Image Image Image Image
