10: PIX3: It's a stitch!!
BettyBoo
Post by BettyBoo »
PhotoImpact 3 now has Cool360 built in - this used to be a separate application. Cool360 will enable you to stitch photographs together forming one larger photograph. This can be quite useful when you want a picture of something quite wide but you are unable to take a single picture of it with your digital camera.
Let us take a look at these 4 photographs and see how they can be merged into one.
I took these photographs with the intention of stitching them together later, to do this I picked out a common feature - in this case it was the line of the floorboards at the top of each picture. Then make a mental note of where the left edge finished so that when taking the next shot I would get the right edge to start just inside where the last one finished - allowing for the pictures to slightly overlap each other.
:idea: Important: :idea:
You can only join images that share the same data type and are either Grayscale or True Color.
COOL 360 only works with base images; objects cannot be stitched. To stitch an object, it must first be merged onto the base image.
Step 1.
Open all the pictures in PhotoImpact X3 that you want to stitch together.
Step 2.
Click one picture to make it active.
Step 3.
Open Cool360 by clicking Photo / Cool360 on the tool bar.
Step 4.
Let us now look closer at the bottom right corner of this screen
Stitch Options are
You can play around with these settings for different effects - press the preview button to see the results, alter the selected settings if necessary.
Step 5.
Click the OK button when you are happy with the result.
Step 6.
Select the crop tool to tidy the picture up.
And drag a border out with your mouse
Then click the apply button to finish off.
Here is the completed picture
Image Master
useful
Post by Image Master »
Thank you for this useful tips.
