For VideoStudio, MediaStudio Pro, VideoGraphics Lab, Cool3D
Ron P.
Re: Suggested work flow by SJJ1805 for Video Creation
Post by Ron P. »
In the Editor you can open the Preferences dialog by File menu>Preferences or by Pressing F6 on your keyboard, then on the General tab you can set the location for a working folder for VS to use.
In the Burn module open the Preferences by clicking on the icon in the lower-left
The working folder setting is located on the first tab..
Phillip
Post by Phillip »
Again, thanks for sending the pics of the working folder and the Burn Preferences folder, Ron P.
Both the 'Working Folder' and the 'Burn module' are pointing to the right locations.
The funny thing is, I can open VS and can not open to edit, Project.vsp. Nothing happens when I try to open the .vsp project. It doesn't even try to load the files comprising the project. The vsp file itself is in the right location and it has 1,168 KB. However, on the 'Share' menu, I only have three choices available, 1) Create Disc, 2) DV Recording 3) Share Video Online. When I click 'Create Disc', then I can preview the whole project in the Previewer on the 'Add Media' page and create another disc.
To me, this is saying that somehow I locked the project into the 'Create Disc' mode and VS won't let me open it in order to make corrections. Does that make sense?
Phillip
Black Lab
operating_system: Windows 8
Post by Black Lab »
No, because you can't "lock" a project. Sounds like your project somehow became corrupted. Unfortunately I don't think it can be recovered. That's why it's best to incrementally save your project as Project A, Project B, etc. Then, if something bad should happen, you can go back to a previous project version and don't have to rebuild the entire thing from scratch.
BrianCee
Post by BrianCee »
Just a thought - if you can see the project .vsp file - next thing I would try is to create a copy of it in Windows Explorer but give it a totally different name - say 'renamed.vsp' or something you will recognise later - then see if you can open the new one in VS.
But do I also understand from your questions that you went direct from the editing window into the 'Create Disc' window and burned a disc - it is usually recommended to create a video file first from your project - then when you open the Create Disc window delete the file automatically carried in and then load your newly created file - it is known amongst experienced users that going stright into the disc window and burning the video already there can give various problems - also that way your .vsp file is safely out of the way when you create a disc.
Phillip
Post by Phillip »
Thank you all for your help! Ron P., Black Lab and last but not least...BrianCee!!
I tried a few ideas myself and then decided to use the backup copy that I hadn't backed up in quite a while.
This has certainly been a learning process and a good one at that, because I've decided to make some changes in order to fine tune the final copy.
Since I burned a CD of the completed Project, I monitor it on a laptop to be sure I'm using the right music for certain scenes, transitions, etc. Also, now I often 'Save' the Project in 'Project.vsp' and then I save a backup of the same Project under a totally different name.vsp.
Thanks Black Lab for also reminding me of a backup file. And especially thanks for letting me know that ...You can't 'lock' a project!
BrianCee. initially I tried to open a back-up file with a copy of the project including the same name, the only difference was 'Copy of Project.vsp' but it wouldn't open in VS. After reading your advise I went into Windows Explorer and renamed it with a totally different name, but it still will not open in VS.
I really appreciate your advice about first making a 'video file'. From now on that will be standard procedure before burning a CD.
Again, thanks gentlemen for taking time to assist me, I truly appreciate all your individual input.
Phillip
raymack
motherboard: GIGABYTE Z77-D3H
processor: i7-3770_3.40GHz_3.90GHz
Video Card: AMD Radeon HD 7800 Series
Hard_Drive_Capacity: 2 Terabyte
Monitor/Display Make & Model: Dell SP2208WFP
Corel programs: PSP x2 x3 x4 x5 x6 x7 x8
Post by raymack »
sjj1805 wrote:Suggested work flow by SJJ1805 for Video Creation
Following recent discussions on the forum I have come to the conclusion that it would be more efficient for me to create my suggested work flow as a separate thread to those already in existence in an attempt to avoid confusion caused by the suggested methods made by other users.
The way that I view the entire process of getting from source to completion is to split the process up into 3 distinctive steps.
Step 1. Capture.
Step 2. Edit.
Step 3. Share.
Hi Steve,
I just wanted to say thank you for a good post. This has helped me immensely with the quality of DVD I can now produce. A simple answer, but it works very well.
Regards Ray
