Cannot find script
hdrabkin
Corel programs: Paintshop Pro x9, Aftershot Pr
Cannot find script
Post by hdrabkin »
I just purchased the Selective Color Script Bundle from within PSP 2019 and installed; restarted program when install said finished. I cannot find this in the list of scripts. Where should this have been installed?
LindaLB
Re: Cannot find script
Post by LindaLB »
Mine were installed here:
Program Files (x86)\Corel\Corel PaintShop Pro 2018\Languages\EN\Scripts-Restricted\Selective Color
I don't know if you have other PSP Versions, but if you don't find your scripts under \Corel PaintShop Pro 2019, check your other version folders in this path. Although I installed from PSP2019, the scripts were installed under my PSP2018 version
hdrabkin
Post by hdrabkin »
Well, although I do uninstall previous just after installing a new version of PSP, there are always some remnants of the program directories that are not removed. So I did check in there; the one for x8 didn't have the languages directory; x7 and x6 did have, but the EN directories were blank. In fact, searching on "Selective Color" came back with zero hits. 2019 does have the Languages\EN\Scripts-Restricted directory which does have some scripts, but not the one I purchased. I submitted a ticket to Corel Support but am getting no answers. I'd like to get a real installer for these on my desktop so I can run it manually and see what happens.
motherboard: Alienware M17xR4
ram: 6 GB
Post by LeviFiction »
Try looking in here: C:\Users\YOURUSERNAME\AppData\Local\VirtualStore\Program Files (x86)\Corel\Corel PaintShop Pro 2019\Languages\EN\Scripts-Restricted
If, for any reason, a program lacks the permissions to edit the restricted Program Files location, Windows will create what it callsa "VirtualStore" where the files will be placed instead. These are located in your AppData\Local\VirtaulStore folder.
hdrabkin
Post by hdrabkin »
Checked; the only folder in C:\Users\YOURUSERNAME\AppData\Local\VirtualStore\Program Files (x86)\Corel was for corel pdf fusion; no Paintshop PRO
cosmicDread
motherboard: MSI MPG Z390 Gaming PRO
processor: Intel Core i9-9900K
ram: 32 GB
Hard_Drive_Capacity: 6 TB
Corel programs: PaintShop X5, X6, X8, X9, '18, '19, '20
Post by cosmicDread »
A lot of times, I've used 'Agent Ransack' to find installed files. The program is fast and works very well.
Agent Ransack is free software produced by Mythicsoft:
https://www.mythicsoft.com/agentransack/
When the majority of the people on Earth are wanting the Galactic Federation to show themselves, then they will.
ram: 6 GB
So I bought the scripts the test out. The installer is downloaded to AppData/local/temp/*randomtoken*/Selective_Color_Script_Bundle.exe
PSP let's you re-download and install, then when the installer asks you to agree to the license you can go looking for it. It'll say there until it's finished installing. Just like with LindaLB it installed itself properly where it was supposed to for me.
jrmach
motherboard: EUROCOM SKY X9E2 powered by premamod.com
processor: Intel Core i7 6700K 4.00GHz
ram: 32.0GB
Video Card: 4095MB NVIDIA GeForce GTX 1070
Hard_Drive_Capacity: 3tb m.2SSD
Monitor/Display Make & Model: PnP-Monitor (Standard) 1920x1080 pixels 120Hz
Corel programs: Pretty much all of them except cad....?
Post by jrmach »
I just purchased the ultimate script bundle and have the same issue. Does not show up in psp2019 and cannot find pspscript files in any of the locations. I contaceted Corel support and was put on a list to be contacted. (I hate there support system they want the money now but we will help you later....)
(o o)
-ooO--(_)--Ooo-
Jrmach
hdrabkin
Post by hdrabkin »
I have a similar problem. I purchased this script through PSP2019; Had problems then, so was given a link to the installer, which worked. However, I recently purchased psp2020 and removed psp2019; Upon trying to re-install the script either through the program (my library) or from installer, it just goes through as if it's installing, then finishes but nothing happens. NO script anywhere.
Corel support sent me a link to the installer gain (seems to be the same file), where I have the same result.
. first support told me it can only be installed through the program, but then sends me the installer anyways.,
I tried reinstalling a script, purple tint (free); no problems.
I tried looking everywhere for this script.
hdrabkin
Post by hdrabkin »
I just used the Agent Ransack search engine tool.
It did find a folder n C:\ProgramdData\Selective Color Script Bundle, but it's empty. It has the creation date of 1/23/2019, when I first installed the program for psp2019; AND, it has last access date as today, the last time I attempted to install it.
Other than that, no other instances of a folder Color Script *
