Video Clips Altered
Zelenabel
Corel programs: Corel Video Studio 2021 Ultimate
Re: Video Clips Altered
Post by Zelenabel »
Okay, the entire folder is 4.41 GB.
I believe my laptop already has OneDrive (at least that's where it says all my screenshots get stored lol). Just would need to know how to go about actually using it to share here.
You would have to upload the files to your One Drive, to the right of your task bar should be a cloud icon, right click – Help and Settings for View On Line
You should be able to create a new folder to upload your files.
Once done you will be able to share the folder by copying a share link.
Today I have tried to replicate the project but try as I might I cannot get the duplicate blue frames other than by me doing it manually.
Can you attach a VSP that displays the blue frames, simply zip the vsp and attach to your post, I’ll see how I get on with that.
If the project showing the gaps is a separate VSP, could you provide that as well, cheers
Zelenabel
Post by Zelenabel »
Hello,
So the entire folder is 4.1 GB. I have One Drive on my laptop (at least that's where my screenshots seem to go lol). I think I know how to get the 4.1 GB folder there, but wouldn't know how to go about sharing it?
Davidk
ram: 8Gb
Hard_Drive_Capacity: 5_8Tb
Post by Davidk »
Given Trevor's remarks about an association with slip slide roll and stretch, when playing with the project file, select the customise toolbar icon in the TL space and uncheck those 4 options (they are on by default), and report if there is any notable difference in project performance?
One Drive
If you have one drive on the PC with the package, then open it and sign in, and locate the public folder. Select it. Click on upload, navigate to the package folder and select it/Ok. The package should be uploaded now to the public folder: how long that takes depends on your broadband upload speed. When the upload is finished, a folder icon with the package name will appear in the Public folder. Select the public folder address that appears in the browser address bar, and copy it. Paste that address in a follow up post here, and viewers can choose to download the package using that address.
Zelenabel
Post by Zelenabel »
Hello,
Sorry it took so long!
Hoping I did everything correctly. Let me know!
https://1drv.ms/u/s!AseEXs0UIGkngjf4_Tk ... K?e=TUhyLU
Thanks for that link, downloaded the files ok
Most confusing when running the project.
Difficult to see if the duplicated frames in blue have replaced the video frames or additional at the end if the clip.
I'll do a bit more digging but to be honest I dont think I am going to improve things
If I remove the image from the end of the clip I am left with a very short section that does not make sense.
As for the project properties they are set for 1280 x 720 having a frame rate of 29.97 when the video clips are using 59.94fps, effectively you are only seeing half of the frames available.
Whether that has a bearing on what went wrong I do not know.
I believe you will have to create this project again, make sure the project properties match the video files properties.
Post Updated
I have managed to replace the still image with the video by using the Replace Mode option far right of tool bar.
Then I simply drag the original video file to the timeline over the same clip.
Most clips were replaced whilst a few needed to have the frames deleted
Attached is the updated VSP
Please rename the file to use VSP as its file extension then open using 2021
test to 59fps.VSP.txt
(192 KiB) Downloaded 10 times
