Duplicating tracks
tafandi
Corel programs: VideoStudio Ultimate 2020
Duplicating tracks
Post by tafandi »
Hi, in VideoStudio Ultimate 2020 is it possible to duplicate tracks?
For example I have an Overlay Track 1 that has clip+effects etc that I want to reuse as Overlay Track 2 (and just replace its clip with another one). Is it possible to do this?
Thanks.
RobertOZ
Video Card: Radeon HD 5770
Hard_Drive_Capacity: 5.5TB
Re: Duplicating tracks
Post by RobertOZ »
Of course that's possible, hold shift key and highlight range to be copied, right click and select copy then drag down into next overlay track, then right click on a clip and select replace clip
Ken Veal
ram: 32 GB
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2019Ult.PhotoMirage.VS.2019 Ult
Post by Ken Veal »
If you are asking what I think you are, as long as you have two overlay tracks showing (the number can be selected in the track manager on the left) just drag clip A in overlay track one down to overlay track 2.Select it and when it is highlighted ,click- keep the mouse button pressed and pull it down to where you want it in overlay track 2 and release the mouse button.Then you can replace clip A in o/lay track 1 with what ever you want.Bear in mind that if you have lots of o/l tracks in use the the o/l track number will determine how it is stacked in the video clip, the clips in each o/l track can easily be re ordered by dragging say 5 into 3 and sliding them into position so they all line up under each other.
Ken
are you referring to one clip with an effect applied
is that clip an image or a video clip
tafandi
Post by tafandi »
In my overlay i have multiple clips and effects.. so if i need to duplicte the whole track, I need to copy the clips one by one to the other track? Is there a quicker way to duplicate the track (with all its contents)?
processor: i7-3632QM 2.2 GHz
Post by tletter »
tafandi wrote:In my overlay i have multiple clips and effects.. so if i need to duplicte the whole track, I need to copy the clips one by one to the other track? Is there a quicker way to duplicate the track (with all its contents)?
Have you tried highlighting all the clips on the track that you want to copy and then using the copy option?
gewb
processor: AMD Ryzen 7 2700X
Video Card: AMD R9-270
Corel programs: X10.5 Ult., 2018 & 2020 Ult.
Post by gewb »
tafandi wrote:
Wed Jan 27, 2021 1:57 am
> Click on the first image (the start) of what you want to copy.
> Use the bottom scroll bar to move along until you see the last image (the end) you want to copy.
> Hold down the SHIFT key -
> While holding the SHIFT key click on the last image.
> The section of the track gets bounded in an orange box.
> CTRL+C to copy, move the box to the location on the desired Overlay track and Left Click to paste.
Done.
tafandi
Post by tafandi »
Yeah... if that's the only way then I have to live with that then.
gewb
Post by gewb »
You asked if you needed to copy CLIP-BY-CLIP of an entire track. My answer showed how to do all or only those in sequence that you want in one operation. What more did you want? If marking a start and end point then copy/drop in place is too much to do then indeed you would have to live with that.
