End video on an image
I have an image at the end of the video. When the video ends (stops), I would like the image shown, not go to a black screen. Is there a way to do that? Thank you.
- Davidk
- motherboard: Gigabyte H97M-D3H
- processor: Intel core i3 3_7ghz dual core processor
- ram: 8Gb
- Video Card: on-motherboard Intel HD 4400 graphics chipset
- Hard_Drive_Capacity: 5_8Tb
- Monitor/Display Make & Model: HP E240c video conferencing monitor
- Corel programs: VideoStudio X9,X10,2018,2019,2020
Re: End video on an image
Assuming these are 2 separate clips, put your video in the timeline, and the last item in the TL should be your preferred image: stretch it (drag the closing edge) to last as long as your want. Render it same as project properties, and you should get what you want.
- ram: 16GB
- Hard_Drive_Capacity: 1TB
Your profile doesn't indicate what version of VS you're using.
Are you referring to a VS-rendered video? When a rendered video is viewed, whether the viewer stops and displays the last frame depends on the viewer and not VS. For example, the default behaviour of the MPC and YT viewers is to stop and display the last frame, whilst VLC doesn't.pearson100 wrote:I would like the image shown, not go to a black screen.
