Is there a Bounce in and Bounce Out effect in VS?
Hello again everyone,
I see that there is an Ease In and Ease Out for motion but is there a Bounce In , Bounce Out effect for motion? If so, I don't see it.
Thanks in advance..
Thanks in advance..
- motherboard: MSI X470 Gaming Plus
- processor: AMD Ryzen 7 2700X
- ram: 16GB
- Video Card: AMD R9-270
- Hard_Drive_Capacity: 4TB
- Monitor/Display Make & Model: LG 24MK430
- Corel programs: X10.5 Ult., 2018 & 2020 Ult.
- Contact:
Re: Is there a Bounce in and Bounce Out effect in VS?
What version of VS?
Oh sorry VS 2019 Ultimate
- ram: 16GB
- Contact:
So far no luck. Closest I found is the transition called Run and Stop. Smear is also interesting.
If you want a verticle bounce (up-down) that stablizes to steady, you could create it yourself using Customize Motion.
- ram: 16GB
- Contact:
Just created a verticle bounce in Customize Motion - took about 5 minutes to tweak it the way I wanted. Now I can Copy/Paste attributes to reuse as desired.
Thank you gewb. I was hoping there was a slider
OK Thanks again!
OK Thanks again!
- ram: 16GB
- Contact:
Ureka!
There is a stock transition called Side which slides the next image (resource) from left to right as default but under Transition you can select L to R, R to L, U to D, D to U.
Who knew?
Who knew?
OMG I will have to check out and let you know. Thank you!
I'm playing it with trying to get the bounce effect.
- lata
- Site Admin
- ram: 16 gb
- Video Card: on board
- Contact:
Hi Henry
I am unsure what you are trying to achieve
a transition where one clip is replaced by another using a bounce movement, here you would use the A/B transitions.
Or
Simply animating an object in a bounce motion, customise motion would probibaly do that.
Once created can be saved as a path, view the library Paths for some ideas.
Or
Hello Trevor,
It's actually an effect that was available in Flash and also with JQuery called "Bounce In" and Bounce Out" where the controls would usually be juxtaposed, bundled with "Ease In" and "Ease Out". They come handy using motion, especially with text.
Here's a variation of the effect:
https://codemyui.com/text-animation-bounce-effect/
Hank
Hank
