So many issues with Video Studio 2019
steveoregon
processor: i7 6700K 4Ghz
Video Card: Nvidia GeForce GTX 970
Re: So many issues with Video Studio 2019
Post by steveoregon »
2019Pro keeps crashing if I click on a transition I've put on the video track to adjust its length.
Ditto on this. I just went from X9 to 2019. 2019 simply closes with no explanation. I will usually try again 1-2 more times, eventually it's successful. NEVER, EVER did X9 close or crash.
pepegota
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Post by pepegota »
I accidentally placed a chapter mark on and could not remove it. The computer locked up. This would be a good program if they just removed the bugs for 2020. I completed the project in Power Director without issue. VS has a better work flow than PD, but only when it works, else a constant save is required.
BurnUnit
motherboard: BIOSTAR Group A780L3B
processor: 2.80 gigahertz AMD Phenom II X4 830
Video Card: onboard
sound_card: onboard
Monitor/Display Make & Model: Samsung 941BW
Corel programs: VideoStudio ProX10
Post by BurnUnit »
DH88Comet wrote:
Tue Jul 23, 2019 2:33 pm
4. Unable to put Fade to Black (or any other) transition at the end of a project. Get message 'The video clips are too short to apply transition effect. Unable to load library.' Clips are over twenty seconds
I know this is an older post, but just in case someone else is having the same problem adding a Fade to Black or other transition to the end of their video;
Try adding a black background segment to the end of your video first, maybe 3 to 5 seconds in length. Then add your transition between the end of your video and the black background. If you're using a 3 second transition it will affect the last 1 1/2 seconds of your video clip and the first 1 1/2 seconds of the black background clip. To work properly the transition has to affect a bit of both clips.
so not really too short.
I assume your clips are on the top video track
Are you sure there is not a separate clip maybe 1 frame long, this can occur if you have used Freeze Frame on the last frame of a video file and difficult to see
Switching to Storyboard View will display the top track as thumbnail, each showing their duration.
