Convert image to RGB 16bits/channel not working
Postby CloudyBright » Wed Oct 17, 2018 3:36 am
File> Preferences> General Program Preferences> Auto Action> Converts Image to RGB 16bits/channel "Always"
This setting does not work. I click on the "Always" button, click OK and it closes - when I double check the setting i find that it had reverted back to "Prompt'.
Is this a bug or why can't I convert photos to 16bit?
CloudyBright
Corel programs: PSP9 - PSP2019 - Corel Draw
Re: Convert image to RGB 16bits/channel not working
Postby Kathy_9 » Wed Oct 17, 2018 4:08 pm
Which version of PSP are you using?
Kathy_9
motherboard: MSI 2A9C
Hard_Drive_Capacity: 750GB
Postby CloudyBright » Thu Oct 18, 2018 3:22 am
Kathy_9 wrote:Which version of PSP are you using?
PSP 2019
CloudyBright
Postby Kathy_9 » Fri Oct 19, 2018 1:06 am
I've never changed any of the auto action settings but I just tested this is 2019, 2018 and X9 and I can confirm your findings that the changes don't stick.
You can submit a ticket with Corel at the following link.
https://www.corel.com/en/contact-us/index.html
Kathy_9
Postby CloudyBright » Fri Oct 19, 2018 3:09 am
Thank you.
Ticket submitted 10/18/2018
CloudyBright
Postby CloudyBright » Sat Oct 20, 2018 2:24 pm
10/20/2018
Corel tech responded that they were able to duplicate this problem and are forwarding it to their Level 2 for further troublehooting.
CloudyBright
Postby Kathy_9 » Sat Oct 20, 2018 2:31 pm
Thanks for reporting back.
Kathy_9
Postby LeviFiction » Sat Oct 20, 2018 3:01 pm
If you're interested I have a workaround for you. It requires use of the registry editor.
1) Close PSP
2) open regedit
3) Go to Computer\HKEY_CURRENT_USER\Software\Corel\PaintShop Pro\X11\General\Fixups
4) Find "IncreaseColorsTo16Bit
5) Change the value to 0 for "Always"
PSP should now show "Always" in the preferences dialog.
Postby CloudyBright » Fri Nov 09, 2018 7:04 pm
Corel's tech support response was to select: Image > Increase Color Depth
That works on a one-by-one basis.
And thanks to LeviFiction for a registry edit work-around which I will probably do when I have a little free time on my hands.
CloudyBright
Users browsing this forum: No registered users and 28 guests
