asGPS: a geocoding plugin for ASP
AfterShot Pro Plugins
Re: asGPS: a geocoding plugin for ASP
Postby seacat » Sun Nov 15, 2015 9:48 pm
Hi dattanchu,
I just today discovered ASP and look for geotag support. Unfortunately on my debian 32 bit system ASP crashes at startup when asGPS 1.4.1 is installed.
Its output is:
Code: Select all
Install Path:           /opt/AfterShot2
LD_PATH:                /opt/AfterShot2/lib:
XLIB_SKIP_ARGB_VISUALS: 1
I have SSE2
Bibble program arguments ("./AfterShotPro")
Loading plugins
Fatal: QMetaType::registerType: Binary compatibility break -- Size mismatch for type 'QPaintBufferCacheEntry' [1024]. Previously registered size 12, now registering size 0.
Aborted
From what I understand is that the plug-in is compiled with an older QT4 library incompatible to my system.I was able to install your version, however nothing shows up in my 32 bit application. Could you please compile a current 32 bit version of asGPS for me?
Or is there anything else I can do to make the official version working?
seacat
operating_system: Linux
ram: 3GB
Corel programs: AfterShot Pro 2
Postby seacat » Sun Nov 15, 2015 9:59 pm
Sorry, my bad, I've schould have read the older posts before...
Version 1.4.0 from last page does work for me. so no hurry.
seacat
ram: 3GB
Postby macr237 » Mon May 23, 2016 10:54 pm
dattanchu wrote:This version should works on Windows, Linux and Mac as well.
Can someone test the Windows and Mac version before I submit this to Corel for inclusion on their site?
Did you submit this to Corel? If so, then why have they not added it to the plugin list? I have got this running on ASP 3.0 with no sign of issues.
Corel developers, are you reading this?
Macr
:arrow: Visit my Flickr page.
macr237
Postby rainer042 » Sun Mar 05, 2017 1:45 pm
Hello,
just tested asGPS on AfterShot 3.2 on Linux x86_64. Works fine. I think you should publish it on Corels ASP plugin page. I was only luck that I found this page here in the forum. I thought it had long since been abandoned, allthough I think its great to have it back again.
Only thing I am missing is a display of GPS heading information (North,...,South) which usually is a value from 0 to 360°, where 0 means the camera was looking to the North. My GPS Tagger provides these information, but in ASP they are not displayed. The tags are:
GPS Img Direction Ref : Magnetic North
GPS Img Direction : 241
Since ASP does not even show these tags it would be great to have asGPS do this job. Would also be great if asGPS was able to embed these tags in the final jpg. ASP by itself does not do this.
Have a nice day, and thanks for reactivating this plugin.
Rainer
rainer042
Postby hannes_hab » Sun Mar 05, 2017 10:04 pm
worked until now
I have a problem with google maps - does anyone know how to fix?
Ubuntu 14.04
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330, Nikon coolscan LS 2000 with Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN7)
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
Postby rainer042 » Mon Mar 06, 2017 8:26 am
Hello,
unfortunately I cannot tell you why google maps does not work for you, but when I tested asGPS yesterday with ASP 3.2 on my openSuSE42.2 (x86_64) system google maps just worked without any problems. Perhaps you should look in log files (ASP, system) to see if you find any hint for the problem you described.
Rainer
rainer042
Postby nostromo » Wed Mar 22, 2017 9:10 pm
hm... unfortunately same here. gives me the same error message as hannes_hab got it.
os: ubuntu 16.04
asp: 3.2.0.205 x64,
asGPS: asGPS_1.4.0-64bit.afzplug
nostromo
System_Drive: N/A
motherboard: asdfasdfasdfasdf
processor: asdfasdfasdfasdf
Video Card: asdfasdfasdfasdf
sound_card: asdfasdfasdfasdf
Hard_Drive_Capacity: 500G
Monitor/Display Make & Model: asdfasdfasdfasdf
Postby hannes_hab » Wed Mar 22, 2017 10:13 pm
I think this is a google problem - I am not using google maps very often - but it seems that google wants to have payment (25.000 map loads per day - simply impossible) nothing changed in my usage - problems since I think about one month (or even less)
I think in an older version of asGPS it was possibe to use BingMaps or Openstreetmaps too ...
regards Hannes
austria
hannes_hab
System_Drive: Z
Postby gpe » Thu May 18, 2017 8:32 pm
nostromo wrote:asGPS: asGPS_1.4.0-64bit.afzplug
Where did you get this version?
gpe
System_Drive: N/A
motherboard: ASUS P8P67 LE
processor: i5-2500k
Video Card: Nvidia GTX550Ti
Monitor/Display Make & Model: Dell U2410
Postby nostromo » Fri May 19, 2017 8:23 am
The links are in this thread:
http://forum.corel.com/EN/viewtopic.php??f=96&t=46351&start=90#p258285
http://forum.corel.com/EN/viewtopic.php?f=96&t=46351&start=105#p306297
http://forum.corel.com/EN/viewtopic.php?f=96&t=46351&start=120#p314943
must have been one of those i used to download the plugin.
nostromo
System_Drive: N/A
Postby gpe » Fri May 19, 2017 11:50 am
Ok thanks.
I had used the last link published:
viewtopic.php?f=96&t=46351&start=120#p315014
but it is the version 1.2.3
gpe
System_Drive: N/A
processor: i5-2500k
Postby andreas » Sun Nov 11, 2018 7:47 pm
Google has changed the API, so that the usage without an API key (like in asGPS) ist not supported anymore. The use of an API key is connected to billing. I am looking into this, what options we can use.
Perhaps one would be to change to OSM, but I remember there have been problems some years ago, which led to disabling this possibility.
Another option would be to let you configure your own api key, use the free options or pay for only your Google api requests.
Andreas
Linux - not Windows
andreas
System_Drive: X
motherboard: Asus in Workstation and Dell XPS Notebook
processor: i7-980 and i7-2720QM
ram: 12GB - 8GB
Video Card: ATI FireGL
sound_card: on board
Hard_Drive_Capacity: 4.5TB Rd10
Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Postby andreas » Sun Nov 11, 2018 7:54 pm
Andreas
Linux - not Windows
andreas
System_Drive: X
ram: 12GB - 8GB
Postby hannes_hab » Mon Nov 12, 2018 12:10 pm
Thank you for the reply Andreas - would be nice if it would work again - without billing ...
A "HowTo" for the free options / or OSM would be nice.
Thanks in advance
regards Hannes
austria
hannes_hab
System_Drive: Z
Postby andreas » Mon Nov 12, 2018 9:32 pm
The current plan is to use the free option, I already set up the account yesterday. But I have to restore the whole compile systems for the three system options. It will take a few days,,,
Linux - not Windows
andreas
System_Drive: X
ram: 12GB - 8GB
PreviousNext
