Blotchy text
Blotchy text
Postby Shepdog1 » Fri Apr 26, 2019 5:38 pm
I finished my project and did a Share/render (MPEG4) to my computer to check my work. The video and sound are fine, but the clips with text are way off. The text looks like you sprayed an easel with Pam then tried to apply the letters with latex paint. The letters are not blurry - - it's more like they are not fully filled in with color. Blotchy. The clips with text also have audio (music and voice-over) and A/B transitions.
Does anybody know what causes this and how I can fix it?
Shepdog1
System_Drive: D
Corel programs: VIDEO STUDIO
Re: Blotchy text
Postby gewb » Fri Apr 26, 2019 6:17 pm
Which version of VS? Which tool to create text? Can you upload and share a portion of the video to a file sharing site?
gewb
processor: AMD Ryzen 7 2700X
Video Card: AMD R9-270
Hard_Drive_Capacity: 5TB
Re: Blotchy text
Postby tletter » Fri Apr 26, 2019 7:26 pm
Shepdog1 wrote:The text looks like you sprayed an easel with Pam then tried to apply the letters with latex paint. The letters are not blurry - - it's more like they are not fully filled in with color. Blotchy.
An image would help to clarify the problem that you're trying to describe.
processor: i7-3632QM 2.2 GHz
Re: Blotchy text
Postby Shepdog1 » Fri Apr 26, 2019 9:53 pm
A P.S. - This threw me because the text appears good on the VS preview screen, so something must have happened during the Share/render process.
The first thing I did was try to figure out how to do a screen shot to add to the original post with my question. Had no luck. Tried pausing the playback and going to Snip Tool, but it wouldn't go for me. Is there a better way to skin this cat?
I'm using VS Pro 8 and used the regular T function to create text.
Shepdog1
System_Drive: D
Re: Blotchy text
Postby canuck » Fri Apr 26, 2019 11:31 pm
Shepdog1 wrote:A P.S. - This threw me because the text appears good on the VS preview screen, so something must have happened during the Share/render process.
Can you give us the exact full name of your version - I have never heard of VS Pro 8
canuck
Re: Blotchy text
Postby Shepdog1 » Sat Apr 27, 2019 5:07 pm
Canuck,
My bad. It is "Pro X8" not VS Pro 8
I'll keep trying to figure out how to get a screen shot to you. Could the transitions and audios be degrading the quality of the text lettering?
Shepdog1
System_Drive: D
Re: Blotchy text
Postby Shepdog1 » Sat Apr 27, 2019 8:33 pm
Finally...the screen shot. The text seems to only lose its quality when it is on a bigger screen. Is there a way to fix this?
Shepdog1
System_Drive: D
Re: Blotchy text
Postby canuck » Mon Apr 29, 2019 10:51 pm
You have not given any information on your project settings,etc so it is hard to make any suggestions. Since nobody else has reported your type of problem, I would think that the problem is in your settings somewhere.
Does it happen with your projects? Can you you create a small project (as a smart package) that shows the problem and upload it to a website such as GoogleDrive. We could then download it from there and we might see what is happening.
canuck
Re: Blotchy text
Postby tletter » Tue Apr 30, 2019 4:41 am
Shepdog1 wrote:Finally...the screen shot. The text seems to only lose its quality when it is on a bigger screen. Is there a way to fix this?
Actually the whole screenshot including the stars is blurry not just the text. Are you playing a low res vid as if it is a FHD or UHD vid?
What is the res of the rendered vid, e.g. 720x480, 3840x2160?
Re: Blotchy text
Postby Shepdog1 » Tue Apr 30, 2019 5:17 pm
720x480.
Shepdog1
System_Drive: D
Re: Blotchy text
Postby canuck » Tue Apr 30, 2019 5:23 pm
Playing a low res 720x480 on a large screen will appear splotchy
canuck
Re: Blotchy text
Postby Shepdog1 » Tue Apr 30, 2019 5:39 pm
Okay. And one final question, if I may: if I render the project in 1080 to my computer, would that foul things up when I upload to YouTube?
Shepdog1
System_Drive: D
Re: Blotchy text
Postby tletter » Tue Apr 30, 2019 7:13 pm
Shepdog1 wrote:if I render the project in 1080 to my computer, would that foul things up when I upload to YouTube?
No, as YouTube can handle up to 2160p (4k) - see https://www.youtube.com/watch?v=v_wDwclu9vc as an example of a 4K rendered video uploaded to YouTube.
Re: Blotchy text
Postby Shepdog1 » Wed May 01, 2019 2:23 am
I think I've been asking the wrong question all along. Using the VS "T" (Title/Text) function, how can you compose text and be sure that it ends up HD?
Does VS have a default resolution for text?
Can I take an existing clip and increase its resolution?
I appreciate the patience of the forum with someone who seems to know almost nothing about making a video. I'm on the steep part of the learning curve.
Bill
Shepdog1
System_Drive: D
Re: Blotchy text
Postby canuck » Wed May 01, 2019 2:51 am
The resolution for the text will be whatever the resolution is of you project. There is not special resolution for text
You can change a 720x480 clip to 1920x1080 clip but the results will not be better. The program has to "create" extra pixels to go from 720 to 1920 which often downgrades the image.
canuck
