Newbie Q's cropping to a set shape
Postby bennyuk » Thu Mar 14, 2019 11:46 pm
Hello,
Very much newbie questions here so I'm sorry if it's num nuts territory.
I have a simple heart shape that i've created for the size that i need and i was just wondering how i can place my heart shape over a picture image that i've got on one of my layers and crop the image under the heart so im left with a picture that is shaped to the correct size of the heart? If my terminology is of point please feel free to correct me as i want to get to know this software correctly. I've only used gimp and inkscape up to now and that was only brief.
Regards
bennyuk
Hard_Drive_Capacity: milton key
Re: Newbie Q's cropping to a set shape
Postby JoeB » Fri Mar 15, 2019 4:12 am
bennyuk wrote:Hello,
Regards
I am assuming that your heart shape is on an otherwise transparent background. I am also assuming that you only want the layer that you are placing the heart on top of to be cropped to the heart shape and not any of the other layers.
If that is the case, place a copy of that heart shape as a layer just above the layer you want cropped. Then select the Magic Wand with Match Mode set to All Opaque. You also might want to check the Anti Alias box and perhaps a Feather of 1 to help make the selection smooth (you can experiment with settings that work best). The click on the heart with the Magic Wand. That should select all of the heart. Then make the layer below the heart active (click on that layer in the Layer's palette. This will place the selection on that layer. Then invert the selection (which will make the selection around everything except the heart shape) and hit the Delete key. This will delete all of that stuff within the inverted selection and leave a heart shape on that layer.
Postby hartpaul » Fri Mar 15, 2019 7:16 am
motherboard: AsusTex P7P55D
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Postby bennyuk » Sat Mar 16, 2019 12:35 am
Thanks guys i shall get on my computer properly tomorrow and start practicing.
Cheers
bennyuk
Postby TimW » Sat Mar 16, 2019 2:26 am
In addition, if you leave the background layer as a <Background> then you will get a white surround around the heart shape after pressing delete. If you first promote the background to a <layer> then you will get transparency around the heart shape.
Thanks JoeB for the refresher.
TimW
motherboard: ASUS M5A99FX
processor: AMD FX8350 8 core 4.0GHZ
Video Card: AMD Radeon HD 6900 Series
sound_card: On Board
Hard_Drive_Capacity: 256GB SSD
Monitor/Display Make & Model: LG 23" Flatron Wide
Corel programs: PSP X8, Knockout 2
Users browsing this forum: terrypin and 12 guests
