Wallpaper Roller 4.69
Postby cosmicDread » Fri Feb 17, 2017 6:18 am
Script Name: 'Wallpaper Roller 4.69'
Compatability: PaintShop Pro X5+
Requirements: Place the main 'Wallpaper Roller 4.69' in a trusted script folder.
This program is written for execution by the Corel's PaintShop Pro X5+ computer programs. The program is designed to create wallpaper, compositions, and textures. One can create wallpaper for a device using one or more images. The program will resize an image to fit a provided resolution, use roller styles to generate abstract backdrops, make 3D effects to add illusion, and provides tools for image placement.
Here are the latest changes made to Wallpaper Roller:
Wallpaper Roller 4.69 (June 17, 2019):
- Fixed three bugs that caused the layout preview to fail to some degree.
- Fixed an error in version checking when loading the last session file.
- Fixed window position drift that occurred in PSP X5 and X6.
- The script no longer requires an open document.
- Drop Shadow now asks for the image border width.
- Made general program improvements.
The main window:
This is the first window to open.
Format Options:
Check out my other work for art ‘Luminosity Mask Drive Thru 2.06':
https://forum.corel.com/EN/viewtopic.php?f=104&t=61441
Best wishes,
Charles Bartley
Wallpaper Roller 4.69.zip
(100.14 KiB) Downloaded 1 time
Last edited by cosmicDread on Wed Jun 19, 2019 4:31 am, edited 149 times in total.
Smooth the rough spots, soften the edges, reflect the light. This is art, no wait, life.
cosmicDread
ram: 32 GB
Hard_Drive_Capacity: 5 TB
Re: Wallpaper creation scripts
Postby JoeB » Fri Feb 17, 2017 10:10 pm
Thanks for sharing!
Re: Wallpaper Roller v4.6
Postby cosmicDread » Mon Dec 17, 2018 11:32 am
During my research, I saw a post by someone who wanted a program that could create this type of format:
I was googling for layout inspiration when I saw this image.
Here is how you can do that with merge cells:
Simplified and clarified, the Merge Cells window in v4.6.
With custom cell placements:
This is the result of the make-over in v4.6.
And lastly, cell margins:
Same tools as before, but cleaner.
cosmicDread
ram: 32 GB
Re: Wallpaper Roller v4.4
Postby cosmicDread » Mon Dec 17, 2018 11:56 am
This is an example of the layout preview as rendered in PSP 2019.
This is the 'Layout' preview:
In the upper-left, the Document title is new.
This is a quick 'Recycled Tech' example:
The results are unpredictable, but that's part of the fun.
This is an example of 'Sand Blast' 3D effect:
The glassy frame material is semi-transparent.
cosmicDread
ram: 32 GB
Re: Wallpaper Roller v4.53
Postby cosmicDread » Sat Feb 02, 2019 2:47 am
This is an example of the 3D effect 'Rad Wave':
The customizable frame uses 'Wave' and 'Twirl' to create interest.
Here is the Used Stencil 3D Effect in action:
The stencil font is used to impress but is not part of the actual effect.
An example of the revamped Maze Mirror:
One can adjust Maze Mirror's line thickness.
cosmicDread
ram: 32 GB
Postby cosmicDread » Thu Mar 07, 2019 10:17 am
This is a render of Floating City. I used a cartoon graphic as a backdrop. I added a shadow layer under the Focal Image. Floating City creates layers of transparent circles and squares based on the luminosity and color of the image:
Maze Mirror was used to make the frame.
RPG Wiz is made in the spirit role-playing games. I kind of enjoy watching the maze draw itself:
This is an example of Clay Tile and RPG Wiz.
cosmicDread
ram: 32 GB
Return to PSP Scripting
