Wallpaper Roller v4.6
Postby cosmicDread » Fri Feb 17, 2017 6:18 am
Script Name: 'Wallpaper Roller v4.6'
Compatability: PaintShop Pro X5+
Requirements: Place the main 'Wallpaper Roller v4.6' in a trusted script folder.
This program is written for execution by the Corel's PaintShop Pro X5+ computer programs. The program is designed to create wallpaper, compositions, and textures. One can create wallpaper for a device using one or more images. The program will resize an image to fit a provided resolution, use roller styles to generate abstract backdrops, make 3D effects to add illusion, and provides tools for image placement.
Here are the latest changes made to Wallpaper Roller:
Wallpaper Roller v4.6:
- Fixed an overflow error that occurred when Composition or Image Margins exceeded image size.
- Fixed an issue with the file corruption checker, where Session files would come up corrupted when they weren't.
- The Format Options and the Session file versions changed.
- Fixed an issue when placing images (same issue as in v4.53).
- Fixed an problem with the Selection rectangle used in image placement where an odd pixel was dropped from the image.
- Changed the behavior of Rad Wave, Curly Cues, and Maze Mirror, and RPG Wiz to create an effect even if there's no images placed.
- Did a make-over on the Per Cell windows.
- Switched methods for Layout calculating, rectangle drawing, and pixelating. Before, the math typically ignored odd row and column division that produce a remainder. Now, this remainder is averaged into the plot using an object: 'OddRC'. The PSP Pixelate function is mostly replaced with a 'pixl8' routine that also distributes this remainder.
- Added a new 3D Effect: RPG Wiz.
The main window:
The Layout group is new v4.6.
Format Options:
The menus have changed appearance in v4.6.
Check out my other work for art ‘CB = Luminosity Mask Drive Thru v2.05':
https://forum.corel.com/EN/viewtopic.php?f=104&t=61441
Best wishes,
Charles Bartley
The download is temporarily off-line due to a complex problem in the code that needs fixing. Wallpaper Roller should be back by April 1, 2019.
Smooth the rough spots, soften the edges, reflect the light. This is art, no wait, life.
cosmicDread
ram: 32 GB
Hard_Drive_Capacity: 5 TB
Re: Wallpaper creation scripts
Postby JoeB » Fri Feb 17, 2017 10:10 pm
Thanks for sharing!
Re: Wallpaper Roller v4.6
Postby cosmicDread » Mon Dec 17, 2018 11:32 am
During my research, I saw a post by someone who wanted a program that could create this type of format:
I was googling for layout inspiration when I saw this image.
Here is how you can do that with merge cells:
Simplified and clarified, the Merge Cells window in v4.6.
With custom cell placements:
This is the result of the make-over in v4.6.
And lastly, cell margins:
Same tools as before, but cleaner.
cosmicDread
ram: 32 GB
Re: Wallpaper Roller v4.4
Postby cosmicDread » Mon Dec 17, 2018 11:56 am
This is an example of the layout preview as rendered in PSP 2019.
This is the 'Layout' preview:
In the upper-left, the Document title is new.
This is a quick 'Recycled Tech' example:
The results are unpredictable, but that's part of the fun.
This is an example of 'Sand Blast' 3D effect:
The glassy frame material is semi-transparent.
cosmicDread
ram: 32 GB
Re: Wallpaper Roller v4.53
Postby cosmicDread » Sat Feb 02, 2019 2:47 am
This is an example of the 3D effect 'Rad Wave':
The customizable frame uses 'Wave' and 'Twirl' to create interest.
Here is the Used Stencil 3D Effect in action:
The stencil font is used to impress but is not part of the actual effect.
An example of the revamped Maze Mirror:
One can adjust Maze Mirror's line thickness.
cosmicDread
ram: 32 GB
Postby cosmicDread » Thu Mar 07, 2019 10:17 am
This is a render of Floating City. I used a cartoon graphic as a backdrop. I added a shadow layer under the Focal Image. Floating City creates layers of transparent circles and squares based on the luminosity and color of the image:
Maze Mirror was used to make the frame.
RPG Wiz is made in the spirit role-playing games. I kind of enjoy watching the maze draw itself:
The No Pic option in Format Options was selected. The background is Egyptian Tile.
cosmicDread
ram: 32 GB
Return to PSP Scripting
