what are the diffrences
Postby jrailer » Sun Aug 26, 2018 12:14 am
so what is different from standard and express
jrailer
Re: what are the diffrences
Postby Kathy_9 » Sun Aug 26, 2018 1:08 am
LeviFiction explained in another topic.
LeviFiction wrote:Okay, so PhotoMirage express does not let you save the file in CPM (Corel Photo Mirage) format. You can only export the result, so no ediitng, saving, and coming back later to pick up where you left off. The export option is limited to specific sizes and qualities. It has presets based on the service you intend to upload to: Facebook, Snapchat, Youtube, etc. The full version has a custom export option where you also get to pick the output type: MP4, WMV, or GIF.
Other than that, as far as I can tell, the tools are exactly the same between the two.
Kathy_9
Postby JCBrown » Mon Sep 03, 2018 4:05 pm
I have the Express version and noted that exporting created a file at 25fps. I'm in NTSC land and want 29.97fps, or at least 30fps.
Does the full version allow different frame rates?
I think that I'll raise this with Corel.
Thanks,
John CB
PSP 2019 Ult
JCBrown
motherboard: 2A9C 1.0
Video Card: AMD Radeon HD 5700 Series
Hard_Drive_Capacity: 15TB
Monitor/Display Make & Model: HP 2710 [Monitor] (27.2"vis)
Corel programs: PSP 2019
Postby Kathy_9 » Mon Sep 03, 2018 5:49 pm
Here's the export dialog box from the full version. You can select from the drop-down but not manually input frame rate.
click for larger view
Kathy_9
Postby JCBrown » Fri Sep 07, 2018 5:58 pm
Thanks for the screen shot. The Express version has no pop down for selecting the fps for export. We should have at least a choice of 25 and 30.
Express also has a fixed export duration of 6s. I guess that we can live with that.
Did Corel move to Europe or something?
John CB
PSP 2019 Ult
JCBrown
Postby Kathy_9 » Fri Sep 07, 2018 11:13 pm
As far as I know they are still headquartered in Ottawa, Canada with a development team in Taiwan.
Kathy_9
Postby juergen » Tue Feb 19, 2019 4:41 pm
Have the express version.
You can change "many" (all?) parameters of the "presets" directly in the ini-Files (in the program-Directory).
Have done this only for a different duration, maybe you can try to change the other parameters (keep a copy of the initial values) also.
juergen
processor: i3-32++
Video Card: GT710
Hard_Drive_Capacity: 2 SSDs
Monitor/Display Make & Model: Dell 2410u
Corel programs: PSP 2019, X9, Jasc PSP 9
Return to PhotoMirage
