Luminosity Mask Drive Thru 2.06
Postby cosmicDread » Thu Mar 16, 2017 3:42 pm
I am sharing a a Paintshop Pro X script I wrote in the last three weeks. It's called:
'Luminosity Mask Drive Thru 2.06'
It's inspired by this post and scripts:
http://forum.corel.com/EN/viewtopic.php?f=104&t=59494
See last post for the latest version.
Cheers,
Charles Bartley
When time runs out, forever becomes an option.
cosmicDread
ram: 32 GB
Hard_Drive_Capacity: 5 TB
Re: Luminosity Masks - follow up
Postby LeviFiction » Fri Mar 17, 2017 4:05 pm
Fantastic UI design. :D
Postby cosmicDread » Mon Dec 17, 2018 11:07 am
The ‘Luminosity Mask Drive Thru 2.06' program:
What it does: The program creates luminosity masks. With a mask, one can modify an image using hue, saturation, and lightness.
Luminosity masks are useful in other applications as well (white balance comes to mind).
How to install: Copy or place the 'Luminosity Mask Drive Thru 2.06' script file in a trusted script folder.
Requires: Paintshop Pro X5+
Luminosity Mask Drive Thru 2.06 (May 21, 2019):
- Fixed a bug that occurred when the last used session file wouldn't load.
- Fixed a bug with the image not updating in Test Drive when using the arrow keys.
- Fixed an over-sight where the last used session file was updated without cause.
- Fixed a problem with the Save dialog window falling behind PSP's window.
- Windows remember their positions between sessions.
- Switched several classes to singletons for speed and simplicity.
- Updated the Main window's appearance.
- The initial Selection state is applied to the final results if the masks are merged.
The Main window looks like this:
I like to apply adjustments to lights and darks separately.
Check out my other work for art, Roller 4.7:
https://forum.corel.com/EN/viewtopic.php?f=104&t=61284
Best regards,
Charles Bartley
Luminosity Mask Drive Thru 2.06.zip
The latest version
(26.19 KiB) Downloaded 20 times
CB - Luminosity Mask Drive Thru v1_35.zip
older stable version
(17.83 KiB) Downloaded 46 times
CB - Luminosity Mask Drive Thru 2_01.zip
an upgrade from v1.35
(19.38 KiB) Downloaded 44 times
cosmicDread
ram: 32 GB
Re: Luminosity Mask Drive Thru 2.06
Postby cosmicDread » Wed May 22, 2019 9:47 pm
I am bumping this thread because the script/program was updated with improvements and fixes.
- Charles
cosmicDread
ram: 32 GB
Return to PSP Scripting
