NEW! Corel PaintShop Pro 2018
ASP 3 Pro Lens Profile - Olympus M.Zuiko ED 14-150 F4.0-5.6
Tips, Tricks, and Results
Postby georgejkw » Thu Oct 05, 2017 6:34 am
I have created a lens profile file for Aftershot 3 Pro that contains lens information for this lens, based on the information in this post.
viewtopic.php?f=95&t=47110
The attached file replaces lens-db.xml in the AS program/supportfiles/Profiles/LensProfiles directory (eg Linux /opt/Aftershot3(64-bit)/supportfiles/Profiles/LensProfiles). Please make a backup of the original before you use this, just in case!
Note that the lens name in this file has been changed to Zuiko Digital ED 14-150 F4.0-5.6 because this is how AS identifies the lens (even for the version II lens I have)
I found that I have to click the Reload EXIF button under lens correction to get Enable correction to apply.
HTH
lens-db.zip
(56.62 KiB) Downloaded 143 times
georgejkw
operating_system: Linux
System_Drive: O
Return to Tips, Tricks, and Results
