Access Denied when extracting plugins in PSP2018
Postby Faye » Sat Aug 25, 2018 5:54 pm
Hi I am new here and looking for help.
I am running Windows 10 and I use PSP2018 64 bit.
When extracting a plugin from WinZip to the plugin folder of PSP2018 I get Access Denied. That administrative privileges may be required.. :?:
I am the administrator..Yes it is set up that way on my computer.
Does anyone know why or can help me with this. :?:
Thank you
Faye
Faye
Re: Access Denied when extracting plugins in PSP2018
Postby Ken Berry » Sat Aug 25, 2018 8:13 pm
I've moved your question to the PaintShop Pro forum as you are likely to receive more -- and more rapid -- replies there.
Postby LeviFiction » Sat Aug 25, 2018 8:46 pm
Starting with Windows 8 administrators all have common user privileges and anything requiring full admin privileges needs to be promoted. It's a security feature to prevent programs running undetected from running with full admin privileges and potentially damaging your systems. If you right-cllick on winzip and use "Run As Administrator" then you should be able to copy to any folder.
The best way, however, would be to create a plugins folder all your own, say in your Documents folder, and add it to the file locations inside PSP.
Postby Faye » Sun Aug 26, 2018 2:38 am
Thank you so much
Faye
Postby ehume » Sun Aug 26, 2018 7:13 pm
I had a similar problem with PSP 2018. I solved it as follows:
Went to 'File > Preferences > File Locations... Plug-ins.' Edited Look-In directory from '.../PlugIns/EN' to '/PlugIns.' Now you should be able to find plugins.
ehume
processor: i7 4770k
Video Card: Intel HD4600
sound_card: no_sound_card
Postby Faye » Sun Aug 26, 2018 8:58 pm
Thank you for this answer. I was trying to add them directly into the program in the plugin folder. I do know the way you told me about. Sometimes the plugins will not work by doing that. Thank you again. I am very appreciate that you took the time to help me.
Faye
