NEW! Corel PaintShop Pro 2018
PSP 2018 - strange response from the clone brush
Postby narrowgauge » Tue Sep 05, 2017 8:09 pm
In my install of PSP 2018 the clone brush does not work as it did. Instead of covering what I don't want with what I do want it covers what I don't want with a pattern of vertical lines. The settings are exactly the same as on my installation of PSP X9.
And what is the overlay supposed to do? Or where is it supposed to do it? It seems to make no difference if it is selected or not.
Any thoughts?
narrowgauge
motherboard: Asus PRIME X370-PRO
processor: AMD Ryzen 5 1400
ram: 32GB
Video Card: Nvidia GTX750 Ti x 2
Hard_Drive_Capacity: 6 Tb
Monitor/Display Make & Model: iiyama Prolite B2780HSU x 3; B2480HSU x 1
Corel programs: PSP 2018
Re: PSP 2018 - strange response from the clone brush
Postby Jean-Luc » Wed Sep 06, 2017 11:16 am
Are you working on the background layer ?
Try to duplicate it as new layer and work on the duplicated.
Or perhaps are you working on an adjustment layer ?
http://www.paintshoppro.eu
Installed PSP Ultimate: X7, X8, X9 and 2018.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Corel programs: PSP X7, X8, X9, 2018
Postby narrowgauge » Wed Sep 06, 2017 2:06 pm
Jean-Luc wrote:Are you working on the background layer?
Yes, I was, a greyscale photograph. But then found I did not have the problem with colour images, and I that could use the tool correctly once I had converted the greyscale photograph to a raster image. I had not come across that before.
Thanks for your answer.
narrowgauge
ram: 32GB
Postby JoeB » Wed Sep 06, 2017 6:58 pm
For clarification, unless your image was originally a vector image it was already a raster(bitmap) image. I assume you mean once you promoted the Background layer (which is already a raster image layer without transparency named Background) you were able to work with it properly. When you promote the background layer the default name applied by PSP is Raster 1, and new added layers are named Raster 2, Raster 3, etc. That's simply to differentiate them from vector layers, which by default are named Vector 1, Vector 2, etc. when they are created. You can rename any layer to any name you want to make them easier to identify for you.
Using PSP 2018 (20.2.0.1 x64)
Postby andrewch59 » Tue Sep 12, 2017 11:06 am
Ok! I have read the previous posts and have no idea what a raster or vector layer is...I am just trying to clean up my photos taken with an 1800s camera. I then scan them into tiff files and put them on PSP for cleaning up. Since upgrading to the new 2018 program I am getting barcode or vertical lines when trying to clone out scratches, please help or can I go back to my fairly dependable 9 ultimate version.
andrewch59
Postby rogerrenfrow » Tue Sep 12, 2017 5:35 pm
I'm having the same problem (at least it sounds like it) with the clone tool. On background layers and promoted background raster layers.
clone brush odd results
I've fiddled with the settings, and it doesn't seem to make much of a change in the result.
rogerrenfrow
motherboard: Asus Republic of Gamers
processor: Core i7-3630QM
ram: 8.148 GB
Video Card: GeForce GTX 670MX
Hard_Drive_Capacity: 428GB open
Monitor/Display Make & Model: Asus default
Corel programs: Paint Shop Pro X5, X6, X9, 2018
Postby Jean-Luc » Tue Sep 12, 2017 9:43 pm
andrewch59 wrote: Since upgrading to the new 2018 program I am getting barcode or vertical lines when trying to clone out scratches,
It is definitively a bug.
What you can do is Increase Color Depth to RGB 8 bit, make your cleaning and revert back to greysacle after the job.
Jean-Luc
Postby hartpaul » Tue Sep 12, 2017 10:21 pm
This appears to be a bug introduced in PSP2018. In past versions (I tested X7 and X9), converting an image to grey scale did not cause any problems with the clone brush.
In PSP2018 an image converted to grey scale (Image > Greyscale) results in problems when using the clone brush.
To get normal operation you must convert the image (Image > Increase color depth) to at least RGB 8 bits / channel to have the clone tool function normally.
Systems XP, Win7, Win 8.1,Win 10 Version 1607 Build 14393.2007 HDD C drive 7200 rpm
motherboard: AsusTex P7P55D
ram: 8 Gb
Hard_Drive_Capacity: 2000 Gb
Corel programs: PSP8,X2 to X9,2018
