PaintShop Pro 2018 Ultimate JavaScript (and other) Error
Re: PaintShop Pro 2018 Ultimate JavaScript (and other) Error
Postby lionel » Sat May 25, 2019 8:39 pm
I have the same problem today in PSP X9
Answering YES or NO on the pop-up just brings it up again.
No other buttons or tabs in PSP respond at all. The program can only be closed using Task Manager but when run again comes up to the same error loop. Same happens if the computer is rebooted.
Obviously a PSP programming bug.
I tried shifting all files out of the folder that PSP was working in hoping the error loop would end but it did not help.
I am thinking that I will have to uninstall PSP and reinstall it. Hesitant to do that while I am overseas traveling but it is no use to me as it is.
lionel
motherboard: Hewlett-Packard 30D9 83.1E
processor: Pentium Dual CPU T2330 1.6 GHz
ram: 2GB
Video Card: Onboard laptop
sound_card: onboard laptop
Hard_Drive_Capacity: 120GB
Monitor/Display Make & Model: Mobile Intel(R) 965 Express Chipset Family Generic
Postby lionel » Sat May 25, 2019 9:05 pm
In PSP X9 it came back to the same error loop every time I ran the program so I could not use PSP at all.
I uninstalled and reinstalled.
Now I can use PSP but I am staying away from the mapping mode.
lionel
ram: 2GB
Postby mku4e » Sun Jun 02, 2019 3:40 am
I think I have found a solution...
After trying multiple things to no avail, I tried this:
1. Right click on paintshop shortcut
2. Click "View File Location"
This should take you to the Corel Painshop folder
(C:\Program Files\Corel\Corel Painshop Pro X9 (64-bit))
3. Scroll down and find the "ResetDB" application
4. Click Run
This worked for me, hopefully it works for you. Best of luck
mku4e
processor: Intel Core i7 770HQ
Video Card: NVIDIA GeForce GTX 1050
Corel programs: Paintshop X9 Pro
Postby Monteiro » Sun Jun 02, 2019 5:43 pm
mku4e wrote:This worked for me, hopefully it works for you. Best of luck
Dont work for me :?
Monteiro
Postby hartpaul » Mon Jun 03, 2019 1:55 am
Worked here . Allowed me to get out of the loop that stops you from using PSP. It does not however allow the Mapping to be used, that I think is a loss as it requires Corel to keep up and make corrections with any changes that Google makes. Corel is unlikely to do that for all versions since the start of Mapping in PSP. I never use this or the sharing to other sites from withing PSP as each of these require that the third party maintain a stable and continuous protocol for passing PSP info over.
As soon as that protocol is changed the "feature" in PSP is broken.
motherboard: AsusTex P7P55D
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Postby Dragonvet » Mon Jun 03, 2019 7:35 pm
mku4e wrote:I think I have found a solution...
4. Click Run
Brilliant! This worked, thanks mate. I wonder why they don't bother adding this to their knowledge base?
Dragonvet
motherboard: Asus Rampage V Editioin 10
processor: Core I7 6850k
ram: 32gb
Video Card: 2xMSI Gefore GTX 980ti
sound_card: onboard
Hard_Drive_Capacity: 14tb
Monitor/Display Make & Model: LG 34UC80-B UltraWide
Corel programs: PSPx9
Postby wpatters1229 » Wed Jun 26, 2019 3:19 am
I can get it to work with running as an admin but then it eventually starts up.
Is there a way to disable the map function permanently? I will never use it. So far the program is not worth keeping. I just bought it too...! :cry:
wpatters1229
motherboard: Gigabyte 333 P55A
processor: Intel i5 750
ram: 8 Gig
Video Card: ATI Radeon HD 7500
sound_card: on board Realtek HD Audio
Hard_Drive_Capacity: 4 Terra
Postby mrbios » Thu Jul 11, 2019 10:32 pm
pwm wrote:Update: I got this response from Corel tech support:
Try resetting your internet settings.
1. Press WINDOWS KEY + R
....r and/or the software.
I couldn't see how that would make any difference, and since the 32bit version works OK, I declined to change my security settings and they closed the ticket. It's a feature I never use, so I'll just have to remember to never click the "globe" icon.
I did it and the same error comes up. There should be a way to remap X5 to launch Chrome by default instead of IE which is out of date.
mrbios
Postby mrbios » Thu Jul 11, 2019 10:38 pm
spitfrog wrote:I have a workaround for X9 64bit (perhaps for X8 and X7 64 too)
It's 2018 files, so this does not solve this problem for 2018
If no, it's easy to roll back. If you still have script errors, initialize PSP with Shift key, and retry.
THANKS! Using Win 8.1 and I closed X5 and doubled clicked the first file with the Registry settings to enable compatibility mode for IE for Corel X5 and NO REBOOT and started X5 it worked instantly! Thanks!
mrbios
Previous
