Moving to 32 bit and previously istalled 2019 ult
Postby Ken Veal » Sun Jan 27, 2019 3:23 pm
Have moved to win 10 from 7.Had upgraded to PSPro 2019 ult 32 bit via an upgrade previously .How do I change the present 64 bit version to 32 bit as my scanner is not recognised using 64 bit. Cant find a 32 bit option anywhere .Also I think I do not have the ultimate version now
Ken
Ken Veal
ram: 32 GB
Monitor/Display Make & Model: Asus VS238H-P 23 inch Widescreen LED
Corel programs: PaintSPro2019Ult.PhotoMirage.VS.2018 Ult
Re: Moving to 32 bit and previously istalled 2019 ult
Postby Kathy_9 » Sun Jan 27, 2019 5:23 pm
You are offered the option of 32-bit, 64-bit or both (recommended) during installation. If you did not choose both you will need to uninstall then reinstall and select both.
There is no difference between PSP 2019 and PSP 2019 Ultimate. It is the same program. Ultimate refers to the extras that come with the purchase. You should have been given separate download links for the extras in your email from Corel.
Kathy_9
motherboard: MSI 2A9C
Hard_Drive_Capacity: 750GB
Postby Ken Veal » Sun Jan 27, 2019 9:55 pm
Thanks for the reply.Have uninstalled and reinstalled a 32 bit version of 2019 .My post was made after a move to Windows 10 from 7 .But 2019 is still showing no scanner found which is a Canon Lide 210.
Help please
Ken Veal
ram: 32 GB
Postby JoeB » Sun Jan 27, 2019 11:15 pm
Just to be clear, have you gone to File>Import>Twain Source to first look for and select a default scanner?
Postby Ken Berry » Mon Jan 28, 2019 12:25 am
Apart from doing what JoeB suggested, have you installed any CanoScan software on your Windows 10? I ask because I have a positively ancient Canon LIDE 25 (bought in the 1990s) which works just fine in TWAIN capture under Windows 10 and is seen and recognized as a TWAIN source by PSP 32 bit. But I also installed CanoScan Toolbox 4.9 which provides the necessary driver for the scanner to be recognized. I suspect that Toolbox version is also quite old, and you might need to do a search on the Canon website to find a version which will work with your model.
You should also check File > Import > From Scanner or Camera as that also works. The GUI it makes available to you is more simplistic than the TWAIN interface, but it still produces a good scan.
(Footnote for those possibly worried that I am working with ancient equipment: I also have a far more modern scanner which comes with my Brother colour laser multifunction centre. It also presents a 32 bit TWAIN interface in PSP and gives me access to much higher scan resolutions than the old Canon. Mind you, for a quick basic scan the Canon is a good and quick alternative...)
Postby Ken Veal » Mon Jan 28, 2019 10:17 am
Have not installed anything else from Canon.Did though just install the latest/another driver, separated the scanner usb extn cable connection connections and reconnected and am now back in business
Ken Veal
ram: 32 GB
Postby Ken Berry » Mon Jan 28, 2019 6:47 pm
Glad to hear it's now working for you! :D
Postby juergen » Mon Feb 11, 2019 1:27 pm
Ken Berry wrote:...
Unfortunately, it is so that (most of SOHO) scanner / printer manufacturers provide no more TWAIN drivers (for 64 bit).
You can for nearly every scanner use WIA on windows: https://docs.microsoft.com/de-de/window ... -startpage
In PSP like Ken wrote with File > Import > From Scanner or Camera, even at 64 Bit.
Alternatively / maybe: https://www.hamrick.com/ Vuescan (chargeable)
juergen
processor: i3-32++
Video Card: GT710
Hard_Drive_Capacity: 2 SSDs
Monitor/Display Make & Model: Dell 2410u
Corel programs: PSP 2019, X9, Jasc PSP 9
