Help deleting DVDWorkshop2 ( I'm sorry)
Moderator: DVDDoug
Postby DiscCoasterPro » Fri Feb 26, 2010 12:31 am
I'm sorry to bother you again, but after following the instructions to a letter, I decided to do a registry search just on the long shot that something ULEAD related remained.
What I found was a ton of things. Typing them all out is laborious but here is the tip of the iceberg.
Please Advise .. :(
hkey_classes_root\clsid\{039cd332-fb27-4f71-93d2-db6610bb84d3}\InprocServer32
(default) c:\program files\common files\Ulead systems\dvd\XDIscLayer.dll
ThreadingModel Both
Doing find next I got ...
hkey_classes_root\clsid\{083863f1-70de-11d0-00a0c911ce86}Instance\{35d8c6f7-7799-4a41-bc05-787442f3a96d}
(Default) (value not set)
clsid {35d8c6f7-7799-4a41-bc05-787442f3a96d}
FilterData 02 00 00 00 00 00 20 00 02 00 00 00 00 00 00 00 30 70 69 33 00 00 .....
Friendly Name Ulead Video Deinterlace Filter
Doing another find next ....
HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{A880A320-6DFA-47EE-B5F9-6A9481F2605F}
This goes on and and on and on with different locations but same names and then different locations and different names
Like ... DVD\LDCdBldr.dll
(default) value not set
clsid .... blah blah ....
Friendly name UleadAC3 Audio Decoder 2
Doing another ....
HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{CF957F20-77FE-4192-A59F-95CA43BD04BA}
blah blah
blah blah
Friendly name Ulead Mpeg splitter
Doing another ....
HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{CF957F30-77FE-4192-A59F-95CA43BD04BA}
blah blah
friendly name Ulead MPEG audio Decoder
Doing another ....
blah blah
friendly name Ulead MPEG Video Decoder
Doing another ....
HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{CF957F50-77FE-4192-A59F-95CA43BD04BA}
blah blah
Friendly name Ulead MPEG Encoder
Doing another ....
HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{CF957F80-77FE-4192-A59F-95CA43BD04BA}
blah blah
Friendly name Ulead MPEG Muxer
Doing another ...
HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{CF957FA1-77FE-4192-A59F-95CA43BD04BA}
blah blah
Friendly name Ulead File Source (Async.)
DiscCoasterPro
Postby sjj1805 » Fri Feb 26, 2010 12:48 am
Deleting things from the Registry is DANGEROUS and can cause your computer to stop working and might even require you to re-install your operating system.
ONLY DELETE the entries you were advised to and DO NOT TOUCH ANYTHING ELSE. Yes there will be other entries scattered about the Windows Registry, these should not cause your system any harm and should be LEFT ALONE.
Many programs install dozens even hundreds of registry entries, for example If you install Norton AntiVirus (Yeuk) and then search your Windows Registry you will find hundreds of entries.
Postby DiscCoasterPro » Fri Feb 26, 2010 5:38 pm
Thank you. I ran CCleaner on the registry and it cleared all those. I made a backup first and took your advice not to manually play with those entries.
thank you.
DiscCoasterPro
Postby Coral » Sun Feb 28, 2010 2:35 pm
I always keep an image of my HDD and after I install a new software and be convinced that everyting remained as it should, then I will backup again including the new software. Othwise if there is anyting wrong I can always go back to where I was before.
Coral
sound_card: On Board
Return to DVD Workshop
