Wallpaper Roller v4.52
Postby cosmicDread » Fri Feb 17, 2017 6:18 am
Script Name: 'Wallpaper Roller v4.52'
Compatability: PaintShop Pro X5+
Requirements: Place the main 'Wallpaper Roller v4.52' in a trusted script folder.
This program is written for execution by the Corel's PaintShop Pro X5+ computer programs. The program is designed to create wallpaper, compositions, and textures. One can create wallpaper for a device using one or more images. The program will resize an image to fit a provided resolution, use roller styles to generate abstract backdrops, make 3D effects to add illusion, and provides tools for image placement.
Changes made to Wallpaper Roller:
Wallpaper Roller v4.5:
- Fixed an exception error in the escape route of 'Format Options'.
- Fixed semi-transparent input image handling. Semi-transparent images will now frame.
- Fixed an oversight where the background image wasn't checked for usage.
- Completely transparent images can now used. They just can.
- Roller styles use a mask to preserve transparency.
- Improved 'Drop Shadow's handling of semi-transparent images.
- Added internal silent mode for when user chooses interactive mode.
- Added new 3D effects: 'Sand Blast' and 'Rad Wave'.
- Added a session file corruption check.
- Included an 'Extra' gradient file named 'Rainbow' inside the .zip file.
Wallpaper Roller v4.51:
- Fixed a problem with Ceramic Chips where missing border parts messed with layer organization.
- Added a minute effect to "Drop Shadow".
- Added a new 3D effect: 'Used Stencil'.
- Improved performance by switching from non-zero type masks to opacity type masks when making 3D effects.
- Moved 'Automate' check button to 'Process' group as it now controls several areas:
-- 3D effects;
-- Several Roller Styles;
-- User permissions:
--- Resize image;
--- Merge layers;
--- Convert vector to raster;
- Included an 'Extra' gradient file named 'Sun Arc' inside the .zip file.
Wallpaper Roller v4.52:
- Fixed Border Line and Sand Blast 3D effects. There was a problem where a layer was missing, causing the shadow layer to be bombed by the effect process.
The main window:
The Automate button has moved reflecting its expanded functionality.
Format Options:
To reuse 'Format Options', save them using a preset.
Check out my other work for art ‘CB = Luminosity Mask Drive Thru v2.05':
https://forum.corel.com/EN/viewtopic.php?f=104&t=61441
Cheers,
Charles Bartley
Wallpaper Roller 4.52.zip
Peruse 'Read These' files for more info.
(93.2 KiB) Downloaded 2 times
Last edited by cosmicDread on Sat Feb 16, 2019 12:27 pm, edited 64 times in total.
Smooth the rough spots, soften the edges, reflect the light. This is art, no wait, life.
cosmicDread
ram: 32 GB
Hard_Drive_Capacity: 5 TB
Re: Wallpaper creation scripts
Postby JoeB » Fri Feb 17, 2017 10:10 pm
Thanks for sharing!
Re: Wallpaper Roller v4.4
Postby cosmicDread » Mon Dec 17, 2018 11:32 am
During my research, I saw a post by someone who wanted a program that could create this type of format:
I was googling for layout inspiration when I saw this image.
Here is how you can do that with merge cells:
Group, divide, and slice.
With custom cell placements:
The 'No Pic' option is new.
And lastly, cell margins:
No picture. No problem.
cosmicDread
ram: 32 GB
Postby cosmicDread » Mon Dec 17, 2018 11:56 am
This is an example of the layout preview as rendered in PSP 2019.
This is the 'Layout' preview:
In the upper-left, the Document title is new.
This is a quick 'Recycled Tech' example:
The results are unpredictable, but that's part of the fun.
This is an example of 'Sand Blast' 3D effect:
The glassy frame material is semi-transparent.
cosmicDread
ram: 32 GB
Re: Wallpaper Roller v4.5
Postby cosmicDread » Sat Feb 02, 2019 2:47 am
This is an example of the 3D effect 'Rad Wave':
The customizable frame uses 'Wave' and 'Twirl' to create interest.
Here is the Used Stencil 3D Effect in action:
The stencil font is used to impress but is not part of the actual effect.
cosmicDread
ram: 32 GB
Return to PSP Scripting
