Can't get narration to work
PostPosted: Thu Dec 06, 2018 5:18 pm
by Fishn3
Hi, first time member. I'm using Corel Video Studio Pro X8, maybe more dated than what others use, I don't know. It seems to work just fine except for doing any narration. I've got a headset with microphone that plugs into a jack on the front of my computer (Dell Inspiron 660). I go to Record/Capture and then Voice over. A little screen pops up for me to test the recording level (Window Audio Mixer) but the screen is dead and doesn't respond at all. I'm thinking I may be forced to use the recording deck I use for my music projects to make some MP3 files to import, but I shouldn't have to do this. Would anyone have any suggestions? Would a USB headset make any difference? Puzzled on this as everything else works fine and I've made some good videos otherwise :|
Re: Can't get narration to work
PostPosted: Thu Dec 06, 2018 6:24 pm
by weaver
Is your headset working with other programs like skype etc? Probably you need to configure the system correctly.
PostPosted: Thu Dec 06, 2018 7:06 pm
Check in Windows' Control Panel > Sound > Recording to see what is set as the default device. Your headset should be listed when plugged in, and you should have that as the default when you are trying to do narrate.
Another option, which is the one I use, is to ignore the narration/voiceover function in VS. Instead, I write my script as a series of entries. Then I use the freeware Audacity audio editor to record -- and where necessary touch up -- my voiceovers. I export these as .wav files, though you can also use mp3. Then I insert them in their appropriate places in the video, adjusting any other background audio levels (e.g. the original audio on the video, plus background music) as necessary to give primacy to my voiceovers. IMHO this sounds more professional in the final video, and of course avoids any fumbles you might make in a "live" narration.
PostPosted: Fri Dec 07, 2018 1:07 am
by Fishn3
Good advice, I'll try all the options above. Sounds like Audacity might be the way to go :)
