How do you export 4K video?
Postby DumbQuestionSource » Sun Jul 08, 2018 6:12 pm
I know there's endless videos and little guides on how to export 4K video in VideoStudio, but none of them work for me, so I'm sure it's a basic problem I'm missing, but I've looked and can't find anything to address it. The standard frame sizes for any of my encoders don't include 3840x2160 and I can't select user-defined--it's grayed out. How would I go about either adding an additional standard frame size or setting a user-defined frame size? Also, compression is locked to 20000Kbps or lower for MPEG-4 and I'd like to encode at higher quality, given 4K video.
VideoStudio X9, video is XAVC-S 60Mbps UHD/30Hz footage. VideoStudio can read it fine and can even re-encode to the exact same settings, so I can edit the video and save it, but I can't go below the heavy 60Mbps encoding of the source file because any attempt to manually edit the MPEG-4 settings runs into the 1080p frame sizes and compression rates. Same problem whether I try to change it from Share or in the project properties. Since it can re-encode it with changes, I figure I should be able to edit an ini or something somewhere to add some default 3840x2160 encodings but I can't find anything.
DumbQuestionSource
processor: 6600K
ram: 32GB
Video Card: 1080 Ti
Hard_Drive_Capacity: 1.5TB
Corel programs: VideoStudio X9
Re: How do you export 4K video?
Postby lata » Sun Jul 08, 2018 7:20 pm
From Settings Project Properties – New I was able to set properties as
MPEG-4 Files
24 bits, 3840 x 2160, 25 fps
Frame-based
H.264 Main Profile Video: 65000 Kbps, 16:9
44100 Hz, 16 Bit, Stereo
MPEG AAC Audio: 128 Kbps
From Share – mpeg4 there are default templates, the last option uses -- XAVC S MP4 4K (3840 x 2160, 50p, 65Mbps)--, also there are options via “+” to create our own templates.
From F6 Preferences, make sure Show Messages is selected.
Start a new project, When we add our video to the timeline, the show messages allows us to match the project settings to our video files properties. If our videos are 4K then those properties will be used.
Limitations to 65,000kbps, so some issues using higher rates of 99999kbps
If you cannot do that then please explain in more details as to what you are trying to achieve.
Postby Ken Berry » Sun Jul 08, 2018 8:01 pm
DumbQuestionSource -- Can you confirm that you see something like this when you click the downward pointing arrow (indicated by the red arrow) when you go to Share and choose MPEG-4 as your output:
Postby bifer » Mon Jul 09, 2018 8:03 am
lata wrote:Hi
Yes, Videostudio is locked to 65.000 kbps as maximum ... everything I tried to get to higher rates is impossible.
bifer
processor: i7-4720 HQ 2.60 GHz
Video Card: NVIDIA GeForce GTX 960M + Intel HD4600
Hard_Drive_Capacity: SSD 1+2TB
Corel programs: ASP3, PSP2018 + VS2018 Ultimate
Postby lata » Mon Jul 09, 2018 9:51 am
Please read this similar post
viewtopic.php?f=1&t=63927&p=358782#p358756
Postby asik1 » Mon Jul 09, 2018 6:14 pm
If I can get a 15sec clip of this 100Mb/s style, I'll see how my VS handles it.
**Although personally I believe that this alleged "missing" 33% of data will certainly wont give 33% loss of apparent practical viewing quality loss.
asik1
motherboard: H170M-E D3
processor: i5-6600
Video Card: ENGT430
Corel programs: VS-X9.2
Postby lata » Mon Jul 09, 2018 7:08 pm
Hi Asik
For what it is worth CVSX9 seems to handle my sample clip much quicker than 2018
I am referring to the reaction times to import and display on the timelines.
Also the time to refresh when changing the timeline durations, fit project in timelines etc.
X9 being much faster than 2018
Postby asik1 » Mon Jul 09, 2018 7:54 pm
lata wrote:Hi Asik
Well, Trevor
Sticking to 19.2 has some benefits...
** What sony did you get?
asik1
processor: i5-6600
Video Card: ENGT430
Postby lata » Tue Jul 10, 2018 9:39 am
good morning asik
I purchased the Sony RX10iv
Postby asik1 » Tue Jul 10, 2018 3:13 pm
lata wrote:good morning asik
Wow... Heavy gun.
** I tried few 'under the hood' ways to get 100mb/s for the mp4 and... no luck.
My tweaks got me weird results even for few known profiles, so further dig is needed.
asik1
processor: i5-6600
Video Card: ENGT430
Postby lata » Tue Jul 10, 2018 4:34 pm
hi asik
are you saying you cannot add a 100mb video or you cannot render to 100mb?
Postby asik1 » Tue Jul 10, 2018 5:51 pm
lata wrote:hi asik
I don't have genuine 100mb clip so I tried to render a 50 one to 100.
I'll try later another trick with odd resolution.
asik1
processor: i5-6600
Video Card: ENGT430
Postby asik1 » Wed Jul 11, 2018 8:39 am
strange issues indeed...
I tweaked few files, rename others and rested my 19.0 folder
Then when I first run VS and loaded my 3840x2160 50K test file, trim it and went to share
this setting pop up
I have know idea where 105K came from, I didn't enter that in any of my tweaks.
But it's not ez to keep it. it showed first under Mobile
**I'm ending my tests here, as I do not have any need or see any practicality for such high bit rate in my work.
asik1
processor: i5-6600
Video Card: ENGT430
