NEW! Corel PaintShop Pro 2018
PSP-2018 menus
Moderator: trueblue
PSP-2018 menus
Postby Nena » Sun Sep 10, 2017 8:12 pm
Please, in the PSP-2018, does anyone know how to disable the automatic scrolling of the menus? When I click to choose a plugin, the listing is limited by the size of the screen, and the others are hidden.
You have to click on the small lower arrow so that they all appear.
I have already searched in all possible settings, in Customize, I have selected all the menu scrolling options, but this behavior remains. Is this specific to the PSP-2018 and is there no way to make it work as in the PSP-X9?
Thank you for your help.
Hugs, Nena
Nena
motherboard: ST-4255
processor: i7-2600
Video Card: NVIDIA GeForce 210 [Display adapter]
sound_card: Realtek Digital Output
Hard_Drive_Capacity: 1999
Monitor/Display Make & Model: LG IPS236
Corel programs: Paint Shop Pro X8
Re: PSP-2018 menus
Postby JoeB » Sun Sep 10, 2017 9:47 pm
I have PSPX7 through 2018 and get the same scrolling with al of them, so it's not just a 2018 issue. I doubt if there is any way to prevent it, although it is strange given that, after your list gets to a certain length (don't know what that is) you will get Plugins 2, 3, etc. So one would think that this would happen any time the plugins listings go beyond the screen height. But unfortunately that's not the case. :-(
Using PSP 2018
Re: PSP-2018 menus
Postby Nena » Sun Sep 10, 2017 9:58 pm
Thank you for your answer.
Here, the PSP-X9 shows the entire menu, with no small arrow at the end. I do not know why on PSP-2018 I can not get the same behavior.
Nena
processor: i7-2600
Re: PSP-2018 menus
Postby patara » Tue Sep 12, 2017 12:47 am
Nena, looking at your 2 examples, it looks clear to me that the X9 list is closer together then the 2018 list. Ok, I overlaid your 2 lists and that is the case.
That is also the case for me between all new Corel versions and my older versions and that is the reason why this is happening, i.e. because the space between the listed Plugins is more in newer versions the list is longer, as I explained to you in the Stat group.
as in this screenshot of mine below, where I overlaid PSPX Plugin list [black text] over PSPX9 Plugin list [white text]
As you can see the PSPX plugin list is closer together than the X9 Plugin list therefore in the same space PSPX can list 8 Plugins but PSPX9 only 7 Plugins.
As an example, the list in my Plugins 2 folder in PSPX, finishes just above my Taskbar, but in X9, the same folder which lists the exact same number of Plugins finishes 8 Plugins past where PSPX finishes, hence it requires the down arrow for scrolling. I do find it very annoying because the last item in the list always sits partially under my Desktop Taskbar and is difficult to read and click on.
Although I have never complained, I've always wished Corel would fix this and set it out like in older versions, or at least set it to useable screen height.....Patricia
patara
motherboard: GA-Z77X-UD3H P5K
Video Card: GeForce GTX 670
Hard_Drive_Capacity: 250 GB
Monitor/Display Make & Model: Dell 2407WFP
Corel programs: PSP7 to PSP2018
Re: PSP-2018 menus
Postby Nena » Tue Sep 12, 2017 11:51 am
Thank you for your response Patricia, waiting if Corel can clarify this menus things.
Hugs, Nena
Nena
processor: i7-2600
Re: PSP-2018 menus
Postby patara » Wed Sep 13, 2017 4:52 am
Nena, if you want Corel support, then you will have to contact them directly.
As far as I know, no Corel Support Staff answer here.
patara
Re: PSP-2018 menus
Postby Nena » Wed Sep 13, 2017 1:12 pm
Thanks Patricia, go to contact the Corel Support.
Hugs, Nena
Nena
processor: i7-2600
Users browsing this forum: JoeB, LeviFiction and 15 guests
