aconnell wrote:I'm using my digi Sony HandiCam and capturing the video using a firewire card and the Roxio Easy Media Creator v7 OR ULead Video Studio 8. So no real device to capture other than my digicam.
thecoalman wrote:I think there's a bug in the program....
Especially considering the fact that this has suddenly appeared, apparently this wasn't an issue before? That's just specualtion on my part though.
The point is why bash your head against the wall. Try a different route. If it's happening to so many then why fight it?
Complain if that's the case
jwarner wrote:maddrummer3301 wrote:Uncompressed video I think is at least 1gig a minute.MD
An uncompressed AVI Video file at 640 X 480 takes 900kb per frame. At 30 fps 24bit color that works out to 26.37 MB per second or 1.582 GB per minute.
jwarner wrote:In my (humble) .
Why would you want to fill up your hard drive with information that says "a blue bit here, a blue bit here, a blue bit here, etc. etc." when it is far more effective to say, the next 2 million bits are blue.
Encoding video needs much more processing obviously and early digital video cameras couldn't do it effectively so opted for an uncompressed format. Newer cameras don't have that problem so use compression (MPEG2 or MPEG4). Soon, I expect, all video cameras will record in MPEG4 format directly to flash media so there will be more more mechanical nonsense to deal with for storage.
Just because Ulead seems to have a problem handling MPEG's doesn't seem sufficient reason in my mind to save a bunch of storage-hungry AVI's. Especially since, if your eventual goal is to burn a DVD, it will have to end up as an MPEG2 at some point!
[/list]thecoalman wrote:You don't capture DV footage, you transfer it.It's lossless transfer, When you plug the cam you need to choose the capture plug in I think? Choose DV, you are in fact copying the file from your cam to HD.
You do realise DV and AVI are one in the same. It's DV-AVI...there's other kinds of AVI, I'm guessing you were capturing to a uncompressed one? maybe 60gigs a hour? Or do we have a miscommunication here?
FWIW, I just completed processing the 2-hr movie mentioned in my last post. And, wonder of wonders, I was able to edit, author and burn a useable, viewable DVD WITH NO SYNC PROBLEMS!
Sadly, it was not done in UVS8 but rather in UVS7.
Actually I didn't realize that the DV-AVI was uncompressed. I need to go back and check to see how I can tell UVS8 or EMC7 how to capture compressed AVI... correct?
Users browsing this forum: Bing [Bot] and 7 guests
