Error Installing Corel Video Studio X5 Trial
Postby haider2026 on Sat Jul 14, 2012 1:33 pm
Hi...
I downloaded the tiral version of video studio x5. When i run the installation wizard, it stops the process and asks me to remove the program instead. But that too does not function and i get a messge saying that the program is not installed... Can anyone please help?
haider2026
ram: 4gb
Re: Error Installing Corel Video Studio X5 Trial
Postby lata on Sat Jul 14, 2012 3:32 pm
Welcome to the forums
Very strange indeed, do you have any other Corel Video Studio versions installed? Although that should not make any difference, just curious.
Did you manage to run through some of the installation, then on the second attempt caused these errors?
Does your PC's Programs and Features list Corel VS X5?
Are you installing the program using Administrator rights.?
ram: 4 gb
Postby haider2026 on Tue Jul 17, 2012 5:04 pm
Hi...
1: I had ulead 11.0 installed which i uninstalled later.
2: I downloaded the trial version of CVS X5 a few days ago and it may not have installed properly as i left the desk for my lunch break :)
3: I came back and searched the computer for the program but could not find it.
4: I then downloaded it again and that is when the installation wizard gave me this message if i wish to uninstall cvs5 and its settings etc.
What can i do to fix this? I have searched the computer but the program is not there. Could it be that some elements of the program may be somewhere in the computer?
haider2026
ram: 4gb
Postby teknisyan on Tue Jul 17, 2012 11:35 pm
You may want to manually remove the incomplete install of VS X5, you can do that by following these steps.
http://corel.force.com/index/articles/e ... dio-Pro-X5
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
teknisyan
processor: Intel Corel i5
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Postby lata on Wed Jul 18, 2012 9:55 am
haider2026 wrote:2: I downloaded the trial version of CVS X5 a few days ago and it may not have installed properly as i left the desk for my lunch break :)
Can we assume you are using a personal computer owned by you, that you are signed in as administrator.
or is this a works PC probibaly connected over a network/server?
ram: 4 gb
Postby haider2026 on Wed Jul 18, 2012 1:34 pm
It is my personal laptop that i use at work. Is there a software i can use to uninstall any components of vsx5 that may have been installed incorrectly?
haider2026
ram: 4gb
Postby lata on Wed Jul 18, 2012 4:07 pm
Hi haider2026
Abiel gave a link in an earlier post with details to 000012696 - Manually Removing Corel VideoStudio Pro X5
Abiel Corel NA wrote:You may want to manually remove the incomplete install of VS X5, you can do that by following these steps.
ram: 4 gb
Postby haider2026 on Wed Jul 18, 2012 5:12 pm
Guys i am ready to give up :( ... I have looked everywhere but the folders and registries are not there.
haider2026
ram: 4gb
Postby haider2026 on Wed Jul 18, 2012 5:37 pm
I have found the following link. Please advise if i should follow the instructions given. Although corel videostudio does not show up on add/remove programs list but the rest of the thigns mentioned are there; microsoft visual c++ redistributable, smart sound common data, smartsound quicktrack 5, windows media encoder 9 series. Shall i go ahead and remove these?
http://www.youtube.com/watch?v=BD_Zkji7vmw
p.s. i did use corel videostudio x4 trial version last year.
haider2026
ram: 4gb
Postby lata on Wed Jul 18, 2012 7:13 pm
Just don't know what to suggest, as you are using 64bit the files should be under the Program Files (x86) /Corel folder.
When searching, some files are hidden, you must select to show hidden files and folders to locate all files.
When you try to install, the file is extracted to a temp folder, for my pc it was here:-
C:Usres/User Name/AppData/Local/Temp/Corel Video Studio.....
These are used to install the program
After installation these files are deleted, if installation is terminated these files may not be removed.
Can you check the location, if they exist clean the temp folder, then try to re-install.
Have you considered a System Restore to before your lunch break
Just noticed the other post
Try using these details first.... 000005468-Uninstalling VideoStudio Pro X4
ram: 4 gb
Postby haider2026 on Thu Jul 19, 2012 1:27 pm
Finally!!!!!!! I just had to clear the temp folder completely and the installation worked after that. :))
For anyone with the same problem please follow these step:
Go to start and type %temp% and hit enter to open the temp folder.
Once there select all files
delete
Note: System may not allow deletion of some files. Just press ingore when that happens.
Thank you all for your help.
haider2026
ram: 4gb
Postby lata on Thu Jul 19, 2012 4:01 pm
Hi haider2026
Thanks for the feed back and glad you managed to finally install the program.
I had another problem running X5 on a 64 bit pc, the library files showed an error when selecting some of them, requesting a Re-Link.
I do not think this has been reported as a problem so it may be just my system.
If you have similar problems, run the program in XP Compatibility mode
ram: 4 gb
Postby haider2026 on Thu Jul 19, 2012 4:03 pm
Will do and thanks again for all the help.
haider2026
ram: 4gb
Postby Ken Berry on Thu Jul 19, 2012 8:49 pm
I have now done five major projects using X5 on my new (and first) 64 bit system -- so far with no such problems!
processor: i7 2.2 GHz
sound_card: On Board Intel
Hard_Drive_Capacity: 640 GB
Postby lata on Fri Jul 20, 2012 2:20 pm
Hi Ken
Thanks for that, the clips affected are Images....just to explain, selecting images from the X5 library requested a re-link, as you know the re-link window indicates the last know location, this showed it to be under Program Files, however the software installed to Program Files (X86). (64Bit)
I have just disabled XP Compatibility mode and the problem has occurred again......
Interestingly and i have just noticed this, it is looking for images in the X4 folder structure. Obviously I have X4 installed as well.
Even though I run through the re-link it does not work ..... with the clip still requires re-linking.
Once I had set the program to run in XP compatibility mode everything worked ok.
Very Strange......
ram: 4 gb
cron
