skier-hughes wrote:Simplisticly, if your camcorder shoots in 4.3, you can set it to shoot in 16.9 style, but it isn't true 16.9, it is anamorphic and is a way of pretending your 4.3 is 16.9.
You can achieve it in post, so while editing you crop the 4.3 video to 16.9 size.
Early camcorders shot in anamorphic, but all newer ones will shoot in true 16.9, they have 16.9 sized chips to record the video, whereas early versions sometimes only used a 16.9 section of this chip.
erdna wrote:Carroll
I understand that you want to get 16:9 in YT. Your 4:3 video with the black bars in YT can look as if evrything looks smaller than it should be, Then it is anamorphic, and forcing it to 16:9 in YT is OK. If your 4:3 image looks nomal then everything will look broaden in a forced 16:9 YT mode. If you then want a good looking video you need to clip top and/or bottom .
skier-hughes wrote:What is the make and model of your camcorder?
It does sound like it is pretend 16.9 to me.
lata wrote:Hi Carroll
Thanks for the image, it confirms at least to me that your video is standard DV-Avi using 4:3 aspect ratio.
If you change the aspect ratio to 16:9 you will loose some detail top and bottom of the video as image below
OK
Try this.....................
The Youtube link is tagged as Private and as such only you can view, change the viewing options to Public, you may have to post another link.
Post Notifications, we are aware of some problems with auto mails, however Admin are forwarding any problem mails, can you check your mail spam folders for the originals and mark them as not spam.
When you access the board there is a link at the top marked "View your Posts"
this will list all your personal posts in order.
I will be away for a few days so cannot reply till Thursday
The video looks fine to me, its looking good, I assume you happy with the results.
If you wish to burn a dvd then you have to convert the DV-Avi to Mpeg2.
You will use either Custom or Make Movie Templates Manager to create a template.
The other option is to edit the project properties to use Mpeg2.
Then Share-Create Video File - Same as project properties.
Anyhow, well done.......
Users browsing this forum: accentstencil, Google [Bot] and 4 guests
