asGPS: a geocoding plugin for ASP
AfterShot Pro Plugins
Re: asGPS: a geocoding plugin for ASP
Postby patrickh on Mon Apr 30, 2012 4:03 pm
Thanks andreas. Problem solved.
patrickh
operating_system: Mac
System_Drive: N/A
motherboard: Macintosh
processor: 2.93 GHz Intel Core i7
Video Card: ATI Radeon HD 5750 1024 MB
sound_card: MacNone
Hard_Drive_Capacity: 1Terabyte
Monitor/Display Make & Model: iMac 27"
Postby binoyte on Wed May 02, 2012 3:01 am
I will explain my choice for the checkboxes colours.
First, it's in the ASP tone.
The black colour means "unchecked" and it is the same black as the edit field. The white is the same white as the font colour and notch in ASP.
The grey is logically in between. Such a tricolour can be seen in the curve level tool
As a colourblind, I have trouble to distinguish some kind of yellow-green and green-red.
I can feel some difference if the two colours are close together. But if there is just one, I have always a doubt : is that green, is that red ?
If you want coloured checkboxes, Red blue yellow is fine, but they don't match ASP's tones.
Adding symbols is also a good idea. If we can draw what we want I suggest something like :
X : nothing
- : between
√ : always (the square root is for a notch...)
Fedora 16 - 64 bit. .
binoyte
operating_system: Linux
System_Drive: Z
Postby martvi on Wed May 02, 2012 4:35 pm
Hi Andreas
I am very glad with asGPS. It works fine for me.
One question though: is there any possibility to set a defauit location? The Googl;e map starts somewhere in the Atlantic Ocean by default now, and most of the time my photographs are made in the Netherland.
Thnx
Mart
martvi
System_Drive: L
motherboard: Asus Unknown
processor: AMD Athlon 4
Video Card: NVidia GeForce 8600
sound_card: Unknown
Hard_Drive_Capacity: 26 TB
Postby binoyte on Wed May 02, 2012 5:40 pm
yes the default location is 0N 0W. It could be useful to add some options :
* last position on startup
* default position on startup
binoyte
System_Drive: Z
Postby binoyte on Thu May 03, 2012 6:03 pm
I try this for checkboxes.
I you want the *.svg files, tell me.
binoyte
System_Drive: Z
Postby hannes_hab on Thu May 03, 2012 10:51 pm
would it be possible to find (filter) images which already have GPS Data?
I work with the nikon P6000 (sometimes GPS writing from this camera is ok) and with ASP in catalog mode.
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon coolscan LS 2000 with Vuescan
bibble 4, bibble 5, ASP mostly Suse Linux 11.4, sometimes WIN XP
hannes_hab
System_Drive: Z
motherboard: Asus Pundit II M3A320
processor: AMD Phenom II X4 925
ram: 4GB DDR2
Video Card: ATI Radeon HD4550 512MB
sound_card: SBx00 Azalia + ATI R700 Audio Device
Hard_Drive_Capacity: 260GB
Monitor/Display Make & Model: LG W2442
Postby HCS on Fri May 04, 2012 7:11 pm
I would like that as well. Actually, i would expect the standard product to allow that. GPS coordinates are stored in the picture file, so they should be extractable for the catalog. It should be able to find ones without GPS coordinates. I haven't tried that, though, so i don't know whether it does.
HCS
motherboard: MAC F221BEC8
processor: Intel Xeon 6-core
ram: 48GB
sound_card: on board sound
Monitor/Display Make & Model: Eizo CG241W
Postby nyukuri on Mon May 07, 2012 5:32 am
as I understand this from your posts, one cannot tag several pictures in one step. What about the Batch function? Could I not create a preset which I apply to several images in Batch mode?
nyukuri
Postby grubernd on Mon May 07, 2012 12:52 pm
nyukuri wrote:as I understand this from your posts, one cannot tag several pictures in one step. What about the Batch function? Could I not create a preset which I apply to several images in Batch mode?
copy-sets are your choice of tool here, i would say.
grubernd
System_Drive: G
Postby binoyte on Mon May 07, 2012 3:56 pm
Hi Andreas,
It seems the LIM search doesn't work if there is an apostrophe in the LIM field.
Probably because of the way characters are escaped.
Try «états unis d'amérique» et «états unis amérique»
binoyte
System_Drive: Z
Postby andreas on Mon May 07, 2012 7:16 pm
Aposthrophe problem added to the todos. Jonathan meanwhile compiled a new version but also sees a problem with the external an internal map behaving different on startup. I will have a look into that too. Binoyte, If you want to send the three images, send a PM please. I will include the colors/images in the options.
There are copy set examples in the <Plugin-Dir>/asGPS/resources folder which can be copied into your <BibbleUserHome>/CopySets folder. Perhaps you want to change the keys before.
Andreas
Linux - not Windows
andreas
System_Drive: X
motherboard: Asus in Workstation and Dell XPS Notebook
processor: i7-980 and i7-2720QM
ram: 12GB - 8GB
Video Card: ATI FireGL
Hard_Drive_Capacity: 4.5TB Rd10
Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Postby quadrox on Mon May 07, 2012 9:56 pm
I have finally been able to try out your plugin, and it is absolutely awesome. The coloured checkboxes are slightly confusing, but I'm sure I will get the hang of it. As I promised, I also made a small donation for your effort. Now all I need is a program that can show me all the locations where I have taken pictures already, but I doubt that something like that can be done as a plugin.
quadrox
motherboard: ASUS P6T
processor: Intel Core i7 920
ram: 12 GB
Video Card: AMD Radeon HD 5870
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: DELL U2410
Postby andreas on Tue May 08, 2012 9:25 pm
current colors are traffic lights: Green = drive even if a walker crosses, Yellow = drive if no one is crossing your way, Red = stop and do not drive, even if the crossing is free ;-)
Andreas
Linux - not Windows
andreas
System_Drive: X
ram: 12GB - 8GB
Postby quadrox on Tue May 08, 2012 9:43 pm
Ah, I suppose it specifies which values it will be allowed to set when pressing the "tag" button? I haven't really had the time to play around with the plugin much yet, but I'm looking forward to do so. I have sooo many pictures to tag...
quadrox
ram: 12 GB
Postby Serschele on Wed May 09, 2012 7:29 am
Very useful,
Thanks!
Serge Schmitt
Serschele
System_Drive: Z
motherboard: Acer built-in
processor: AMD built-in
ram: 2GB
Video Card: onboard
sound_card: onboard
Hard_Drive_Capacity: 250Go
Monitor/Display Make & Model: Benq T241WA
PreviousNext
