No Audio sound.
Postby tan how khiang on Thu Apr 19, 2012 5:21 am
Can someone enlighten me to resolve the audio sound problem.
When the video file is saved and burn on DVD disc and play on a DVD player, only the images appear on the TV screen but there is no sound coming out from the speakers.
I'm using Studio Pro X4
:? Tan How Khiang
tan how khiang
ram: 2GB
Monitor/Display Make & Model: Acer Touch screen
Re: No Audio sound.
Postby BrianCee on Thu Apr 19, 2012 7:21 am
Can we please have the FULL properties of the file you have burned to the disc.
BrianCee
Hard_Drive_Capacity: 3TB
Re: No Audio sound.
Postby tan how khiang on Fri Apr 20, 2012 3:53 am
Hi BrianCee
Thanks for your repsonse.
The full properties are as follows:-
File type - Movie Clip (.mpg)
Open with - Windows Media Player
Size - 80.8MB
Attributes - Read only.
Audio
Bit Rate- 1536kbps
Channels - 2 (stereo)
Audio sample rate - 48kH2
Tan How Khiang :)
tan how khiang
ram: 2GB
Re: No Audio sound.
Postby BrianCee on Fri Apr 20, 2012 7:03 pm
sorry Tan How Khiang - could you put the file you are burning to DVD in the timeline of VideoStudio - then right click on it and choose 'Properties' please copy that pop up and post here - it will look like this :-
BrianCee
Re: No Audio sound.
Postby tan how khiang on Sat Apr 21, 2012 4:41 am
HI BrianCee- The timeline that shows the properties file cannot be copied. I therefore have to write the infor below:-
File Name- C:/Programm Files (x86)...
File Format : Window Media Video
File size : 4,484KB
Duration : 12.031secs
Data rate: 3218Kbps
Video: window media video 9
24bits. 1280x720, 29.97-0 frames /sec
Audio : windows media Audio 9.2.
48,000kH2, 16 bits, stereo.
Aspect Ratio : 1.78:1.00
Is editable : Yes
It appears that the above properties is not quite the same as yours. Moreover, whenever I right clip on the different segment of the video clips, the properties also changes.
How Khiang :?
tan how khiang
ram: 2GB
Re: No Audio sound.
Postby tan how khiang on Sat Apr 21, 2012 5:00 am
Hi BrianCee
I have another properties which is identical to yours and are as follows:-
File Name :--
File Format : PAL DVD
File size : 12,924 KB
Duration : 11.520 secs
Video type : MPEG - 2 video
Total Frame - 288 frames
Attributes : 4bits, 720 x 576, 16:9
Frames rate : 25,000 frame/ sec
Data Rate: Variable bit rate (Max 8900 Kbps)
Audio type : Dolby Digital Audio
Total Sample : 552,960 samples
Layer: None
Bit rate : 384kbps
Cheers.
How Khiang
tan how khiang
ram: 2GB
Re: No Audio sound.
Postby tan how khiang on Mon Apr 23, 2012 8:33 am
Hi BrianCee
OK I managed to get the correct properties file and they are asfollows:-
File
File Name : My project\2a Vietnam.mpg
File Size : 273,888KB
Duration : 258.320 secs
Video
Video Type : MPEG-2Video, Upper Field First
Type frames : 6,458 frames
Attributes : 24 bits, 720x570, 16:9
Frame Rate : 25.000 frames/sec
Date Rate : Variable bit rate (max 8000kbps)
Audio
Audio Type : LPCM Audio
Total Sampes : 12,399,360 Samples
Attributes : 48000Hz, 16 bit, Stereo
Layer : None
Bit rate : none.
How Khiang
tan how khiang
ram: 2GB
Re: No Audio sound.
Postby tan how khiang on Wed May 02, 2012 11:13 am
It is quite sometimes of I've forward my file properties but I 've not received any respond from you.
I appreciate it if you would give me your advice. Thanks.
How Khiang
tan how khiang
ram: 2GB
Users browsing this forum: Bing [Bot], ianwoody123 and 11 guests
