Portraits look just awful in ASP -- anyone else see this?
Postby DanInSoCal on Tue Mar 13, 2012 6:46 pm
Portraits are my bread and butter. I do a fair number of them. In B5 I used the Portrait look profile and it effortlessly generated nice, even skin tones, when I added a little saturation, contrast, and vibrance.
In ASP, however, when I adjust those three to get the colors more or less reasonable, the image is horribly contrasty. Faces and skin look awful.
I have seen several posts here regarding various band-aids (set this color down here; use this plugin with this tweak there... etc). I myself have tried tweaking the mid-range contrast with a custom Curves setting, but the results were still unsatisfactory -- unusable, really -- when compared to B5.
In ACR I can fix this by twiddling the mid-range contrast with the Clarity slider. Looks great, almost as good as B5.
Can we get a native solution for this? A "portrait" setting that Just Works?
Thanks,
Dan
DanInSoCal
Re: Portraits look just awful in ASP -- anyone else see this
Postby elslunko on Wed Mar 14, 2012 11:49 am
Give us an example!
Have you tried increasing the luminance of the orange channel? Should be able to accomplish it with the native Color Correction tool or Color Equilizer & Nuance Plugins.
I shoot portraits as well (Though haven't shot many as of late, mostly events) and have found the out of the box settings to be a little over saturated. So I bumped the luminance of those skin tones to bring them towards white and have been happy with the results.
elslunko
operating_system: Linux
System_Drive: S
Postby elslunko on Mon Mar 19, 2012 11:02 am
Hey Dan,
Not a native solution but I've been able to fix some nasty midtones caused by some blue-ish stage lighting by using Wavelet Sharpen's USM at radius 200 on clarity mode. Seems to do the same thing ACR's Clarity slider does.
elslunko
System_Drive: S
Postby DanInSoCal on Sat Mar 31, 2012 4:56 am
Here is a typical example.
50D CR2 File: http://www.dangehlhaar.com/misc/IMG_1615.CR2
Settings for best image:
Bibble: Portrait Look Profile, exposure + 0.5, Contrast +21, Saturation +15, Vibrance +17
ASP: Exposure +0.5, Contrast +10, Saturation +10, Vibrance +10
Bibble JPEG: http://www.dangehlhaar.com/misc/IMG_1615_B5.jpg
ASP JPEG: http://www.dangehlhaar.com/misc/IMG_1615_ASP.jpg
The Bibble image is effortlessly clean with smooth skin tones. The ASP image has an intense harshness that I can't seem to get rid of.
If you can make the ASP image look like the B5 image, I will be very happy!
Dan
DanInSoCal
Postby afx on Sat Mar 31, 2012 7:46 am
ASP Contrast +10 when you think the image is already too harsh by default? Sounds strange to me.
I would not touch Saturation but use only vibrance.
But looking at this particular sample, I think the profile for the 50D should be redone.
Don't see that type of default rendition with my Nikons nor the Oly.
cheeers
afx
The AfterShot Survival Guide
afx
System_Drive: N/A
Video Card: FirePro 4900
Postby ferdinand-paris on Sat Mar 31, 2012 11:36 am
I'm not doing a lot of colour portrait work at the moment, I work mostly in B&W. However, I did a small colour job a few nights ago under stage lighting using my new (s/h) D3s and I had a similar struggle with the ASP rendition. I know the Canon guys are happy with the new profiles, and AFX seems content with the Nikon ones, but to be honest I have to wrestle with colour more than I did with B5, and esp with skin tones, when shooting Nikon (D300, D700 and now D3s).
F_P
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Postby AsterixEtObelix on Sat Mar 31, 2012 3:56 pm
hi ,
well as I mention in an other post you can use 3rd parties plugin, and you can get nice results. I created for me a preset "skin" which use Bez and Color equaliser. of course I use also the contrast and luminosity.
here is my results (less flashy than yours because that s my preference) with the XMP file
AsterixEtObelix
System_Drive: N/A
motherboard: Debian squeeze 64
processor: Intel
Postby AsterixEtObelix on Sat Mar 31, 2012 3:59 pm
Oups the XMP file is not authorized... so here it is
Code: Select all
<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
<rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
  <rdf:Description rdf:about=""
    xmlns:dmf="http://www.bibblelabs.com/DigitalMasterFile/1.0/"
    xmlns:dmfversion="http://www.bibblelabs.com/DigitalMasterFileVersion/1.0/"
    xmlns:bset="http://www.bibblelabs.com/BibbleSettings/5.0/"
    xmlns:blay="http://www.bibblelabs.com/BibbleLayers/5.0/"
    xmlns:bopt="http://www.bibblelabs.com/BibbleOpt/5.0/"
   dmf:versionCount="1">
   <dmf:versions>
    <rdf:Seq>
     <rdf:li>
      <rdf:Description
       dmfversion:software="bibble"
       dmfversion:softwareVersion="2008.1"
       dmfversion:versionName="IMG_1615.CR2">
      <dmfversion:settings>
       <rdf:Description
        bset:settingsVersion="66"
        bset:respectsTransform="True"
        bset:curLayer="0">
       <bset:layers>
        <rdf:Seq>
         <rdf:li>
          <rdf:Description
           blay:layerId="0"
           blay:layerPos="0"
           blay:name=""
           blay:enabled="True">
          <blay:options
           bopt:optionchanged="true"
           bopt:hasSettings="true"
           bopt:metaDirty="false"
           bopt:version="8.2"
           bopt:colormode="1"
           bopt:workingspace="2"
           bopt:whiteauto="false"
           bopt:whitetype="8"
           bopt:lwhitetype="8"
           bopt:lmr="1"
           bopt:lmb="1"
           bopt:whitered="65384"
           bopt:whitegreen="65384"
           bopt:whiteblue="65384"
           bopt:whiteowbr="0"
           bopt:whiteowbb="0"
           bopt:autolevel="false"
           bopt:shadowval="0.2"
           bopt:highlightval="0.2"
           bopt:exposureval="0.2"
           bopt:highlightrecval="0"
           bopt:highlightrecthresh="0"
           bopt:highlightrecmono="false"
           bopt:blackPoint="0"
           bopt:fillamount="0.4"
           bopt:fillrange="0.25"
           bopt:autorotate="1"
           bopt:rotateangle="-0.3"
           bopt:sharpensense="6"
           bopt:sharpenrad="0"
           bopt:newsharpen="100"
           bopt:sharpenon="true"
           bopt:bnn_enabled="false"
           bopt:bnn_auto="false"
           bopt:bnn_profile=""
           bopt:bnn_currentprofile=""
           bopt:bnn_turbo="true"
           bopt:bnn_coarse="false"
           bopt:bnn_lstrength="10"
           bopt:bnn_lsmooth="10"
           bopt:bnn_lcontrast="10"
           bopt:bnn_cstrength="10"
           bopt:bnn_csmooth="10"
           bopt:bnn_ccontrast="10"
           bopt:bnn_usmamount="0"
           bopt:bnn_usmradius="1.2"
           bopt:pcenabled="false"
           bopt:pctintmeta="2"
           bopt:red="0"
           bopt:green="0"
           bopt:blue="0"
           bopt:sat="-3"
           bopt:cont="20"
           bopt:hue="0"
           bopt:vibe="3"
           bopt:useHSL="false"
           bopt:useHSV="true"
           bopt:invertRegions="false"
           bopt:layerOpacity="1"
           bopt:selective_color=""
           bopt:curveson="true"
           bopt:curves_m_cn="4,1,2,2,2,2"
           bopt:curves_m_cy="4,20,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
           bopt:curves_m_cx="4,20,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
           bopt:curves_m_imid="4,1,1,1,1,1"
           bopt:curves_m_olo="4,1,0,0,0,0"
           bopt:curves_m_ilo="4,1,0,0,0,0"
           bopt:curves_m_ihi="4,1,60941,65535,65535,65535"
           bopt:curves_m_ohi="4,1,65535,65535,65535,65535"
           bopt:kelvin="5102"
           bopt:tint="14"
           bopt:okelvin="5102"
           bopt:otint="14"
           bopt:lkelvin="5102"
           bopt:ltint="14"
           bopt:ckelvin="5102"
           bopt:ctint="14"
           bopt:cropon="true"
           bopt:croplocked="true"
           bopt:cropstyle="0"
           bopt:cropleft="0.0608765030223985"
           bopt:croptop="0.0393977220399262"
           bopt:cropheight="2"
           bopt:cropwidth="3"
           bopt:cropdpi="1476"
           bopt:cropstickydpi="-1"
           bopt:cropstickyx="2496"
           bopt:cropstickyy="1590"
           bopt:cropmenuitem=""
           bopt:croppercent="0.928589536542078"
           bopt:Date="2012-03-21 15:30:34.270"
           bopt:DigitizedDateTime="2012-03-21 15:30:34.270"
           bopt:title=""
           bopt:Priority=""
           bopt:Category=""
           bopt:SupplementalCategory=""
           bopt:creator=""
           bopt:AuthorsPosition=""
           bopt:rights=""
           bopt:Credit=""
           bopt:description=""
           bopt:CaptionWriter=""
           bopt:City=""
           bopt:State=""
           bopt:Country=""
           bopt:CountryCode=""
           bopt:Headline=""
           bopt:Instructions=""
           bopt:TransmissionReference=""
           bopt:Source=""
           bopt:subject=""
           bopt:IntellectualGenre=""
           bopt:CiAdrCity=""
           bopt:CiAdrCtry=""
           bopt:CiAdrExtadr=""
           bopt:CiAdrPcode=""
           bopt:CiAdrRegion=""
           bopt:CiEmailWork=""
           bopt:CiTelWork=""
           bopt:CiUrlWork=""
           bopt:UsageTerms=""
           bopt:Location=""
           bopt:SubjectCode=""
           bopt:Scene=""
           bopt:tag="0"
           bopt:keywordlist=""
           bopt:rating="0"
           bopt:label="0"
           bopt:warpon="false"
           bopt:warpa="0.0037855"
           bopt:warpb="0"
           bopt:warpc="0"
           bopt:warpresize="true"
           bopt:warpfocal="44"
           bopt:warpcaon="false"
           bopt:warpcarc="0"
           bopt:warpcaby="0"
           bopt:vignetteon="false"
           bopt:vignetterad="50"
           bopt:vignetteamt="0.5"
           bopt:profilemake="Canon SLR"
           bopt:profilemodel="EOS 50D"
           bopt:profilelens="Canon EF-S 17-55mm f/2.8 IS USM"
           bopt:lens="Canon EF-S 17-55mm f/2.8 IS USM"
           bopt:GPSVersionID="2.2.0.0"
           bopt:GPSLatitude=""
           bopt:GPSLongitude=""
           bopt:GPSAltitudeRef="0"
           bopt:GPSAltitude=""
           bopt:GPSTimeStamp=""
           bopt:GPSSatellites=""
           bopt:GPSStatus="A"
           bopt:GPSMeasureMode=""
           bopt:GPSDateStamp=""
           bopt:GPSMapDatum=""
           bopt:GPSAreaInformation=""
           bopt:GPSProcessingMethod=""
           bopt:bMirrorOn="false"
           bopt:bInvertOn="false"
           bopt:rn_enabled="true"
           bopt:rn_smooth_enabled="false"
           bopt:rn_threshold="0"
           bopt:rn_limit="50"
           bopt:enableInputProfile="false"
           bopt:inputProfile=""
           bopt:ferd.bez_enabled="true"
           bopt:ferd.bez_Early="false"
           bopt:ferd.bez_HCL="false"
           bopt:ferd.bez_opacity="100"
           bopt:ferd.bez_saturation="100"
           bopt:ferd.bez_lighten="0"
           bopt:ferd.bez_lightengamma="0"
           bopt:ferd.bez_midi="50"
           bopt:ferd.bez_sigcontrast="0"
           bopt:ferd.bez_sigmiddle="50"
           bopt:ferd.bez_shadows="10"
           bopt:ferd.bez_lowmids="30"
           bopt:ferd.bez_greys="50"
           bopt:ferd.bez_highmids="60"
           bopt:ferd.bez_highlights="85"
           bopt:ferd.bez_shadows4="20"
           bopt:ferd.bez_lowmids4="40"
           bopt:ferd.bez_highmids4="60"
           bopt:ferd.bez_highlights4="80"
           bopt:ferd.ferd_bez_enabled="false"
           bopt:ferd.ferd_bez_RGB="false"
           bopt:ferd.ferd_bez_BW="false"
           bopt:ferd.ferd_bez_lighten="0"
           bopt:ferd.ferd_bez_lightengamma="0"
           bopt:ferd.ferd_bez_midi="50"
           bopt:ferd.ferd_bez_blak="0"
           bopt:ferd.ferd_bez_sigcontrast="0"
           bopt:ferd.ferd_bez_sigmiddle="0.5"
           bopt:ferd.ferd_bez_contrast="0"
           bopt:ferd.ferd_bez_centre="0"
           bopt:ferd.ferd_bez_shadows="10"
           bopt:ferd.ferd_bez_lowmids="30"
           bopt:ferd.ferd_bez_greys="50"
           bopt:ferd.ferd_bez_highmids="70"
           bopt:ferd.ferd_bez_highlights="90"
           bopt:ferd.ferd_bez_shadows4="20"
           bopt:ferd.ferd_bez_lowmids4="40"
           bopt:ferd.ferd_bez_highmids4="60"
           bopt:ferd.ferd_bez_highlights4="80"
           bopt:Equalizer_kb.kbs_enabled="true"
           bopt:Equalizer_kb.kbs_bw="false"
           bopt:Equalizer_kb.kbs_redlum="5"
           bopt:Equalizer_kb.kbs_yellowlum="0"
           bopt:Equalizer_kb.kbs_orangelum="4"
           bopt:Equalizer_kb.kbs_greenlum="0"
           bopt:Equalizer_kb.kbs_cyanlum="0"
           bopt:Equalizer_kb.kbs_bluelum="0"
           bopt:Equalizer_kb.kbs_magentalum="0"
           bopt:Equalizer_kb.kbs_redhue="0"
           bopt:Equalizer_kb.kbs_yellowhue="0"
           bopt:Equalizer_kb.kbs_orangehue="0"
           bopt:Equalizer_kb.kbs_greenhue="0"
           bopt:Equalizer_kb.kbs_cyanhue="0"
           bopt:Equalizer_kb.kbs_bluehue="0"
           bopt:Equalizer_kb.kbs_magentahue="0"
           bopt:Equalizer_kb.kbs_redsat="3"
           bopt:Equalizer_kb.kbs_yellowsat="0"
           bopt:Equalizer_kb.kbs_orangesat="0"
           bopt:Equalizer_kb.kbs_greensat="0"
           bopt:Equalizer_kb.kbs_cyansat="0"
           bopt:Equalizer_kb.kbs_bluesat="0"
           bopt:Equalizer_kb.kbs_magentasat="0"
           bopt:Equalizer_kb.kbs_redvib="3"
           bopt:Equalizer_kb.kbs_yellowvib="0"
           bopt:Equalizer_kb.kbs_orangevib="3"
           bopt:Equalizer_kb.kbs_greenvib="0"
           bopt:Equalizer_kb.kbs_cyanvib="0"
           bopt:Equalizer_kb.kbs_bluevib="0"
           bopt:Equalizer_kb.kbs_magentavib="0"
           bopt:FatToni.FatToniOn="false"
           bopt:FatToni.FatToniHH="0"
           bopt:FatToni.FatToniSH="0"
           bopt:FatToni.FatToniHS="0"
           bopt:FatToni.FatToniSS="0"
           bopt:FatToni.FatToniMid="0"
           bopt:FatToni.FatToniMix="0"
           bopt:FatToni.FatToniCont="85"
           bopt:FatToni.FatToniBaseH="0"
           bopt:FatToni.FatToniBaseS="0"
           bopt:FatToni.FatToniBaseL="100"
           bopt:SphGrain.bSphGrainon="false"
           bopt:SphGrain.bSphGrainRadius="10"
           bopt:SphGrain.bSphGrainSeed="0"
           bopt:SphGrain.bSphGrainHiddenSeed="0"
           bopt:SphGrain.bSphGrainAmount="25"
           bopt:SphGrain.bSphGrainShadow="30"
           bopt:SphGrain.bSphGrainMid="60"
           bopt:SphGrain.bSphGrainLight="20"
           bopt:SphGrain.bSphGrainRandom="false"
           bopt:SphGrain.bSphGrainColorGrain="false"
           bopt:Grid_kb.thirds="false"
           bopt:Grid_kb.goldenrat="false"
           bopt:Grid_kb.goldenspir="false"
           bopt:Grid_kb.squaregrid="false"
           bopt:Grid_kb.spiralcenter="1"
           bopt:Grid_kb.gridsize="100"
           bopt:Grid_kb.gridxcenter="0"
           bopt:Grid_kb.gridycenter="0"
           bopt:MB_ASP_Lightroom.BLACK="0"
           bopt:MB_ASP_Lightroom.WHITE="0"
           bopt:MB_ASP_Lightroom.HIGHLIGHT="0"
           bopt:MB_ASP_Lightroom.SHADOW="0"
           bopt:MB_ASP_Lightroom.CONTRAST="0"
           bopt:MB_ASP_Lightroom.MED_CONTRAST="25"
           bopt:MB_ASP_Lightroom.BLACK_RANGE="50"
           bopt:MB_ASP_Lightroom.WHITE_RANGE="50"
           bopt:MB_ASP_Lightroom.HIGHLIGHT_RANGE="50"
           bopt:MB_ASP_Lightroom.SHADOW_RANGE="50"
           bopt:MB_ASP_Lightroom.ENABLED="false"
           bopt:MB_ASP_Lightroom.EXPOSURE="0"
           bopt:MB_ASP_Lightroom.EXPOSURE_RANGE="50"
           bopt:mdRedEyes.enable="false"
           bopt:mdRedEyes.mdre_sensitivity="150"
           bopt:mdRedEyes.mdre_luminance="80"
           bopt:Mix3.mix3_enabled="false"
           bopt:Mix3.mix3_early="false"
           bopt:Mix3.mix3_exposure="0"
           bopt:Mix3.mix3_red="0"
           bopt:Mix3.mix3_green="0"
           bopt:Mix3.mix3_blue="0"
           bopt:Nostalgia.Nostalgia_enabled="false"
           bopt:Nostalgia.Nostalgia_filter="BW: Red 23A"
           bopt:Nostalgia.Nostalgia_film="BN: Agfa Agfapan 25 Refinal 6min"
           bopt:Nostalgia.Nostalgia_paper="BN: Agfa MultiContrast Premium Filter 0"
           bopt:Nostalgia.Nostalgia_filmid="16018434"
           bopt:Nostalgia.Nostalgia_paperid="62745044"
           bopt:Nostalgia.Nostalgia_dr="9"
           bopt:Nostalgia.Nostalgia_exposure="0"
           bopt:Nostalgia.Nostalgia_darkroom="0"
           bopt:Nostalgia.Nostalgia_dmax="5"
           bopt:Nostalgia.Nostalgia_fred="0"
           bopt:Nostalgia.Nostalgia_fgreen="0"
           bopt:Nostalgia.Nostalgia_fblue="0"
           bopt:Nostalgia.Nostalgia_flatitude="0"
           bopt:Nostalgia.Nostalgia_platitude="0"
           bopt:Nostalgia.Nostalgia_rgb="true"
           bopt:Nostalgia.Nostalgia_print="true"
           bopt:Nostalgia.Nostalgia_indicator="false"
           bopt:Nuance.Nuance_enabled="false"
           bopt:Nuance.Nuance_settings=""
           bopt:Nuance.Nuance_map="false"
           bopt:SiliconBonk.SiliconBonkOn="false"
           bopt:SiliconBonk.SiliconBonkHighlights="true"
           bopt:SiliconBonk.SiliconBonkH="0"
           bopt:SiliconBonk.SiliconBonkL="0"
           bopt:SiliconBonk.SiliconBonkContrast="0"
           bopt:SiliconBonk.SiliconBonkMid="0"
           bopt:SiliconBonk.SiliconBonkSat="0"
           bopt:SiliconBonk.SiliconBonkC0L="0"
           bopt:SiliconBonk.SiliconBonkC1L="0"
           bopt:SiliconBonk.SiliconBonkC2L="0"
           bopt:SiliconBonk.SiliconBonkC3L="0"
           bopt:SiliconBonk.SiliconBonkC4L="0"
           bopt:SiliconBonk.SiliconBonkC5L="0"
           bopt:sadman.splittonion="false"
           bopt:sadman.splittonimono="true"
           bopt:sadman.splittonihhue="0"
           bopt:sadman.splittonihsat="20"
           bopt:sadman.splittonibalance="0"
           bopt:sadman.splittonishue="0"
           bopt:sadman.splittonissat="20"
           bopt:sadman.splittonismooth="100"
           bopt:sadman.texaenabled="false"
           bopt:sadman.texa1on="true"
           bopt:sadman.texa2on="false"
           bopt:sadman.texa3on="false"
           bopt:sadman.texa4on="false"
           bopt:sadman.texa5on="false"
           bopt:sadman.texapreview1="false"
           bopt:sadman.texapreview2="false"
           bopt:sadman.texapreview3="false"
           bopt:sadman.texapreview4="false"
           bopt:sadman.texapreview5="false"
           bopt:sadman.texaopacity1="100"
           bopt:sadman.texaopacity2="100"
           bopt:sadman.texaopacity3="100"
           bopt:sadman.texaopacity4="100"
           bopt:sadman.texaopacity5="100"
           bopt:sadman.texablend1="Normal"
           bopt:sadman.texablend2="Normal"
           bopt:sadman.texablend3="Normal"
           bopt:sadman.texablend4="Normal"
           bopt:sadman.texablend5="Normal"
           bopt:sadman.texae1="None"
           bopt:sadman.texae2="None"
           bopt:sadman.texae3="None"
           bopt:sadman.texae4="None"
           bopt:sadman.texae5="None"
           bopt:sadman.texatexture1="Original"
           bopt:sadman.texatexture2="Original"
           bopt:sadman.texatexture3="Original"
           bopt:sadman.texatexture4="Original"
           bopt:sadman.texatexture5="Original"
           bopt:sadman.texaplacement1="Fit"
           bopt:sadman.texaplacement2="Fit"
           bopt:sadman.texaplacement3="Fit"
           bopt:sadman.texaplacement4="Fit"
           bopt:sadman.texaplacement5="Fit"
           bopt:sadman.texarotation1="Auto"
           bopt:sadman.texarotation2="Auto"
           bopt:sadman.texarotation3="Auto"
           bopt:sadman.texarotation4="Auto"
           bopt:sadman.texarotation5="Auto"
           bopt:sadman.texamirror1="None"
           bopt:sadman.texamirror2="None"
           bopt:sadman.texamirror3="None"
           bopt:sadman.texamirror4="None"
           bopt:sadman.texamirror5="None"
           bopt:sadman.texae1p1="0"
           bopt:sadman.texae1p2="0"
           bopt:sadman.texae1p3="0"
           bopt:sadman.texae2p1="0"
           bopt:sadman.texae2p2="0"
           bopt:sadman.texae2p3="0"
           bopt:sadman.texae3p1="0"
           bopt:sadman.texae3p2="0"
           bopt:sadman.texae3p3="0"
           bopt:sadman.texae4p1="0"
           bopt:sadman.texae4p2="0"
           bopt:sadman.texae4p3="0"
           bopt:sadman.texae5p1="0"
           bopt:sadman.texae5p2="0"
           bopt:sadman.texae5p3="0"
           bopt:sadman.texascale1="100"
           bopt:sadman.texascale2="100"
           bopt:sadman.texascale3="100"
           bopt:sadman.texascale4="100"
           bopt:sadman.texascale5="100"
           bopt:sadman.texax1="0"
           bopt:sadman.texax2="0"
           bopt:sadman.texax3="0"
           bopt:sadman.texax4="0"
           bopt:sadman.texax5="0"
           bopt:sadman.texay1="0"
           bopt:sadman.texay2="0"
           bopt:sadman.texay3="0"
           bopt:sadman.texay4="0"
           bopt:sadman.texay5="0"
           bopt:sadman.typewriteron="false"
           bopt:sadman.typewriterfont1="None"
           bopt:sadman.typewritertext1=""
           bopt:sadman.typewritersize1="10"
           bopt:sadman.typewriterx1="100"
           bopt:sadman.typewritery1="100"
           bopt:sadman.typewriteropacity1="100"
           bopt:sadman.typewritervs1="100"
           bopt:sadman.typewritercolorp1="16777215"
           bopt:sadman.typewriterfont2="None"
           bopt:sadman.typewritertext2=""
           bopt:sadman.typewritersize2="10"
           bopt:sadman.typewriterx2="100"
           bopt:sadman.typewritery2="100"
           bopt:sadman.typewriteropacity2="100"
           bopt:sadman.typewritervs2="100"
           bopt:sadman.typewritercolorp2="16777215"
           bopt:sadman.typewriterfont3="None"
           bopt:sadman.typewritertext3=""
           bopt:sadman.typewritersize3="10"
           bopt:sadman.typewriterx3="100"
           bopt:sadman.typewritery3="100"
           bopt:sadman.typewriteropacity3="100"
           bopt:sadman.typewritervs3="100"
           bopt:sadman.typewritercolorp3="16777215"
           bopt:USM.enable="false"
           bopt:USM.radius="1"
           bopt:USM.amount="100"
           bopt:USM.threshold="0"
           bopt:Vigne_kb.kbv_enabled="false"
           bopt:Vigne_kb.kbv_size="50"
           bopt:Vigne_kb.kbv_strength="-10"
           bopt:Vigne_kb.kbv_ccol="true"
           bopt:Vigne_kb.kbv_falloff="1"
           bopt:Vigne_kb.kbv_shape="0"
           bopt:Vigne_kb.kbv_horzcenter="50"
           bopt:Vigne_kb.kbv_vertcenter="50"
           bopt:Vigne_kb.kbv_factor="0"
           bopt:Vigne_kb.kbv_trans="50"
           bopt:Vigne_kb.kbv_adjustcrop="true"
           bopt:Vigne_kb.kbv_colenabled="false"
           bopt:Vigne_kb.kbv_col="-10"
           bopt:Vigne_kb.kbv_preview="false"
           bopt:Vigne_kb.kbv_desat="false"
           bopt:Vigne_kb.kbv_desaturate="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseon="false"
           bopt:WaveletDenoise2.bSphWaveletDenoiseThresL="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseLowL="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseThresC="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseLowC="0"
           bopt:WaveletDenoise2.bSphWaveletDenoiseDePepper="false"
           bopt:WaveletDenoise2.bSphWaveletDenoiseShowEdge="false"
           bopt:WaveletSharpen2.bSphWaveletUsmon="false"
           bopt:WaveletSharpen2.bSphWaveletUsmRadius="50"
           bopt:WaveletSharpen2.bSphWaveletUsmAmount="100"
           bopt:WaveletSharpen2.bSphWaveletUsmThreshold="0"
           bopt:WaveletSharpen2.bSphWaveletUsmClarity="false"
           bopt:WaveletSharpen2.bSphWaveletLLenable="false"
           bopt:WaveletSharpen2.bSphWaveletLLStrength="30"
           bopt:WaveletSharpen2.bSphWaveletLLiter="3"
           bopt:WaveletSharpen2.bSphWaveletMCStrength="0"
           bopt:WaveletSharpen2.bSphWaveleton="false"
           bopt:WaveletSharpen2.bSphWaveletAmount="50"
           bopt:WaveletSharpen2.bSphWaveletRadius="0.5"
           bopt:WaveletSharpen2.bSphWaveletSharpenDePepper="false"
           bopt:WaveletSharpen2.bSphWaveletEdge="100"
           bopt:WaveletSharpen2.bSphWaveletSharpenClarity="false"
           bopt:WaveletSharpen2.bSphWaveleton2="false"
           bopt:WaveletSharpen2.bSphWaveletAmount2="50"
           bopt:WaveletSharpen2.bSphWaveletRadius2="2"
           bopt:WaveletSharpen2.bSphWaveletSharpenDePepper2="false"
           bopt:WaveletSharpen2.bSphWaveletEdge2="100"
           bopt:WaveletSharpen2.bSphWaveletSharpenClarity2="false"
           bopt:zChannelMixerGroup.zcmEnable="false"
           bopt:zChannelMixerGroup.zcmbw="false"
           bopt:zChannelMixerGroup.zcmbwa="false"
           bopt:zChannelMixerGroup.zcmlockbw="false"
           bopt:zChannelMixerGroup.zcmlockcolor="false"
           bopt:zChannelMixerGroup.zcmrr="100"
           bopt:zChannelMixerGroup.zcmrg="0"
           bopt:zChannelMixerGroup.zcmrb="0"
           bopt:zChannelMixerGroup.zcmgr="0"
           bopt:zChannelMixerGroup.zcmgg="100"
           bopt:zChannelMixerGroup.zcmgb="0"
           bopt:zChannelMixerGroup.zcmbr="0"
           bopt:zChannelMixerGroup.zcmbg="0"
           bopt:zChannelMixerGroup.zcmbb="100"
           bopt:zFramePlug.zframeSize1="0"
           bopt:zFramePlug.zframeColor1="0"
           bopt:zFramePlug.zframeSize2="0"
           bopt:zFramePlug.zframeColor2="0"
           bopt:zFramePlug.zframeSize3="0"
           bopt:zFramePlug.zframeColor3="0"
           bopt:zFramePlug.zframeSize4="0"
           bopt:zFramePlug.zframeColor4="0"
           bopt:zFramePlug.zframeSize5="0"
           bopt:zFramePlug.zframeColor5="0"
           bopt:zFramePlug.zframeDummy="false"
           bopt:zFramePlug.zframeEnable="false"
           bopt:zFramePlug.zframeEnable1="false"
           bopt:zFramePlug.zframeEnable2="false"
           bopt:zFramePlug.zframeEnable3="false"
           bopt:zFramePlug.zframeEnable4="false"
           bopt:zFramePlug.zframeEnable5="false"
           bopt:zFramePlug.zframeCalibration="false"
           bopt:zFramePlug.zframeRatio1="0"
           bopt:zFramePlug.zframeRatio2="0"
           bopt:zFramePlug.zframeRatio3="0"
           bopt:zFramePlug.zframeRatio4="0"
           bopt:zFramePlug.zframeRatio5="0"
           bopt:zFramePlug.xPos1="0"
           bopt:zFramePlug.yPos1="0"
           bopt:zFramePlug.xPos2="0"
           bopt:zFramePlug.yPos2="0"
           bopt:zFramePlug.xPos3="0"
           bopt:zFramePlug.yPos3="0"
           bopt:zFramePlug.xPos4="0"
           bopt:zFramePlug.yPos4="0"
           bopt:zFramePlug.xPos5="0"
           bopt:zFramePlug.yPos5="0"
           bopt:zFramePlug.relativeTo="0"
           bopt:zFramePlug.place="5"
           bopt:Zone_kb.kbz_enabled="false"
           bopt:Zone_kb.kbz_highlight="-1"
           bopt:zPerspectorPlug.zpersEnable="false"
           bopt:zPerspectorPlug.zpersRotate="0"
           bopt:zPerspectorPlug.zpersGridEnable="false"
           bopt:zPerspectorPlug.zpersGrid="256"
           bopt:zPerspectorPlug.zpersTopLeft="0"
           bopt:zPerspectorPlug.zpersTopRight="0"
           bopt:zPerspectorPlug.zpersLeftTop="0"
           bopt:zPerspectorPlug.zpersRightTop="0"
           bopt:zPerspectorPlug.zpersBottomLeft="0"
           bopt:zPerspectorPlug.zpersBottomRight="0"
           bopt:zPerspectorPlug.zpersLeftBottom="0"
           bopt:zPerspectorPlug.zpersRightBottom="0"
           bopt:zPerspectorPlug.zpersmirror="false"
           bopt:zPerspectorPlug.zpersMirrorOffset="3"
           bopt:zPerspectorPlug.zpersCanvasResize="0"
           bopt:zShadowPlug.direction="315"
           bopt:zShadowPlug.zshadowEnable="false"
           bopt:zShadowPlug.dummy="false"
           bopt:zShadowPlug.size="5"
           bopt:zShadowPlug.scale="5"
           bopt:zShadowPlug.edge="10"
           bopt:zShadowPlug.sizeBg="10"
           bopt:zShadowPlug.color="2105376"
           bopt:zShadowPlug.colorBg="4210752"
           bopt:zShadowPlug.relativeTo="0"
           bopt:zShadowPlug.xPos="0"
           bopt:zShadowPlug.yPos="0"
           bopt:zSoftenPlug.softenEnable="false"
           bopt:zSoftenPlug.softenradius="10"
           bopt:zSoftenPlug.softenorton="0"
           bopt:zSoftenPlug.softencombo="1"
           bopt:zSoftenPlug.softenVignette="false"
           bopt:zSoftenPlug.softenProof="false"
           bopt:zSoftenPlug.softenvigSize="50"
           bopt:zSoftenPlug.softenvigShape="0"
           bopt:zSoftenPlug.softenvigFeather="50"
           bopt:zSoftenPlug.softenvigXpos="50"
           bopt:zSoftenPlug.softenvigYpos="50"
           bopt:zSoftenPlug.softenvigRotate="0"
           bopt:zTextPlug.zTextOn="false"
           bopt:zTextPlug.italic="false"
           bopt:zTextPlug.bold="false"
           bopt:zTextPlug.underline="false"
           bopt:zTextPlug.strikeout="false"
           bopt:zTextPlug.overline="false"
           bopt:zTextPlug.size="5"
           bopt:zTextPlug.xpos="50"
           bopt:zTextPlug.ypos="50"
           bopt:zTextPlug.rotate="0"
           bopt:zTextPlug.font="Arial"
           bopt:zTextPlug.text=""
           bopt:zTextPlug.opacity="100"
           bopt:zTextPlug.stretch="100"
           bopt:zTextPlug.color="16777215"
           bopt:zTextPlug.shearv="0"
           bopt:zTextPlug.shearh="0"
           bopt:zTextPlug.scalev="0"
           bopt:zTextPlug.scaleh="0"
           bopt:zTextPlug.projectv="0"
           bopt:zTextPlug.projecth="0"
           bopt:zTextPlug.basesize="0"
           bopt:zTextPlug.textalign="0"
           bopt:zTextPlug.textposh="0"
           bopt:zTextPlug.textposv="0"
           bopt:zTextPlug.shadowEnable="false"
           bopt:zTextPlug.shadowDirection="315"
           bopt:zTextPlug.shadowShift="10"
           bopt:zTextPlug.shadowIntensity="50"
           bopt:zTextPlug.shadowColor="1579032"
           bopt:blplug.bbwenabled="false"
           bopt:blplug.bbwspotA="false"
           bopt:blplug.bbwspotB="false"
           bopt:blplug.bbwhueA="0"
           bopt:blplug.bbwfuzzyA="25"
           bopt:blplug.bbwcolorA="0"
           bopt:blplug.bbwhueB="200"
           bopt:blplug.bbwcolorB="200"
           bopt:blplug.bbwfuzzyB="25"
           bopt:blplug.bbwmode="0"/>
          </rdf:Description>
         </rdf:li>
        </rdf:Seq>
       </bset:layers>
       </rdf:Description>
      </dmfversion:settings>
      </rdf:Description>
     </rdf:li>
    </rdf:Seq>
   </dmf:versions>
  </rdf:Description>
</rdf:RDF>
</x:xmpmeta>
AsterixEtObelix
System_Drive: N/A
processor: Intel
Postby ferdinand-paris on Sun Apr 01, 2012 2:27 pm
I redid the ASP version of that colour job again and made two discoveries. (i) Certainly playing with vibrance helps. (ii) For anyone using Bez, it's worth experimenting with HCL mode - as HCL and HSL do render skin tones quite differently. (I wonder if I should have kept a LAB mode option.) Combining these two got me close to good skin tones quickly.
That shoot was under stage lighting. I also did a shoot today in natural (indoor) lighting, and I thought the ASP profiles were much better than B5 for general colour, and for skin tones in particular. So go figure. However so far I find ASP a touch warm for my taste in outdoor lighting.
F_P
ferdinand-paris
ram: 4Gb
Postby DanInSoCal on Mon Apr 02, 2012 5:54 am
afx wrote:ASP Contrast +10 when you think the image is already too harsh by default? Sounds strange to me.
Point taken. I would love to see a new profile for the 50D, no matter what I do, ASP just looks awful. Should I file a bug report?
AsterixEtObelix: I will try those plugins and settings. However, clearly something is broken with ASP if it can't render skin well all by itself.
Ferdinand-Paris: What camera are you shooting with? Looks like this issue may be specific to skin tones on this Canon. Too warm? I'm certainly not seeing that!
Dan
DanInSoCal
Postby afx on Mon Apr 02, 2012 6:16 am
DanInSoCal wrote: I would love to see a new profile for the 50D, no matter what I do, ASP just looks awful. Should I file a bug report?
I think so...
Compared to what I seen in AS from my cams and others this looks way too contrasty...
cheers
afx
afx
System_Drive: N/A
Postby ferdinand-paris on Mon Apr 02, 2012 8:19 am
DanInSoCal wrote:Ferdinand-Paris: What camera are you shooting with? Looks like this issue may be specific to skin tones on this Canon. Too warm? I'm certainly not seeing that!
Mostly Nikons. That stage lighting shoot was a Nikon D3s. My comments about outdoor lighting was with a D300. I'm also playing with a new Sony NEX-7. I'm getting better results for the Sony out of ASP than I am from a certain other converter from a large digital image software company, but it's still early days.
F_P
ferdinand-paris
ram: 4Gb
Postby DanInSoCal on Mon Apr 02, 2012 6:58 pm
I think so...
I will do so tonight. It would seem "reasonable" -- to me at least! -- that the ASP folks would use a standard scene to test their profiles, which would include a set of skin tones, shades of grey, and colors of various saturations; and then the profiles would be tweaked to end up within some range on various calculated properties, e.g. contrast. I know that there are variations in the sensors, and that these differences would be highlighted at the extreme highlights and shadows. However, the midtone performance -- where it really counts for fine image quality -- should be made to be reasonably consistent.
Dan
DanInSoCal
Postby DanInSoCal on Mon Apr 02, 2012 7:00 pm
I have downloaded your settings and they make the skin tones look "better", perhaps even "acceptable", but I still prefer B5 for my portrait work. Hopefully "afx" is right and it's just a screwed up camera profile. I will file a bug report and hope that I see a marked improvement in a subsequent release.
Dan
DanInSoCal
Postby DanInSoCal on Fri Apr 06, 2012 6:21 am
Any idea about how long it takes to get a response? I filed a bug report a few days ago and haven't heard anything.
DanInSoCal
