pesto126 wrote:Why not see the standardly named XMP file and just add your metadata to that file?
afx wrote:Because the concept is totally broken.
It will not allow for a JPG and a NEF in the same directory with individual XMPs.
You have to thank Adobe for their lack of thinking...
ferdinand-paris wrote:Much smarter people than me with a detailed understanding of XMP claim that B5/ASP could have used the standard XMP, even for the multiple versions in the same folder, by using their own namespaces.
DocBrown wrote: nor can it read XMP data already embedded in files by other applications.
RickHeath wrote:FWIW I've added Custom Sidecar File Definitions in IDI (Tools>Options>Other Settings) of "%Filename.%FileExtension.xmp" for both JPG & CR2 to make sure that IDI will handle B5 & ASP sidecar files correctly if I rename files, move them, etc.
Regards
Rick
afx wrote:DocBrown wrote: nor can it read XMP data already embedded in files by other applications.
What makes you think that? Works just fine with embedded XMP from iMatch.
cheers
afx
Users browsing this forum: Franz Dur and 5 guests
