Plug-in installation help.
Postby Charles+OK on Fri Feb 24, 2012 12:19 am
I'm having no luck installing Wavelet Denoise and Wavelet Sharpen. The instructions on at aftershotpro.com indicate launching the ".afzplug" file or using the ASP install plug-in function. I cannot find such anyway in the downloads no does ASP. What am I doing wrong? I'm running Vista.
Thanks,
Charles
Charles+OK
processor: AMD X2 64
Re: Plug-in installation help.
Postby bananahead on Fri Feb 24, 2012 1:17 am
All plugins should be available from here
The plugin site
bananahead
motherboard: Asus P67
processor: i7 2600k
Video Card: Nvidia 560
sound_card: Asus DX
Hard_Drive_Capacity: 1.5 TB
Monitor/Display Make & Model: Samsung 2393
Postby afx on Fri Feb 24, 2012 2:28 am
Charles+OK wrote: What am I doing wrong?
You did not look at the obvious place ;-)
File->Install plugin...
cheers
afx
The AfterShot Survival Guide
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Postby ferdinand-paris on Fri Feb 24, 2012 7:07 am
bananahead wrote:All plugins should be available from here
The plugin site
Not all. Some plugin authors haven't been given access to this facility.
F_P
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Postby Charles+OK on Fri Feb 24, 2012 10:38 am
cheers
afx
I did that. ASP doesn't see a ".afzplug" file at either my original download location or the default Corel application directory where I moved the unpacked download. Wavelet sharpen downloads as "WaveletSharpen_ALL_T34.zip. Inside I can't find any ".afzplug" files. The same is true for Denoise and the vignetting "gift." Do I need to be in the administrative log-in? I started to check angle, but as I'd installed ASP from a "user" log-in, ASP there was still in uninstalled trial download status. I wasn't sure what a second configuration would do.
Charles
Charles+OK
Postby afx on Fri Feb 24, 2012 10:43 am
Charles+OK wrote:Wavelet sharpen downloads as "WaveletSharpen_ALL_T34.zip. Inside I can't find any ".afzplug" files.
Throw away your web browser.
afzplug files are ZIP files. The browser tries to be intelligent and renames them.
Not really smart.
cheers
afx
afx
System_Drive: N/A
Postby claudermilk on Fri Feb 24, 2012 11:25 am
Yes, the files fhould have .afzplug extensions. To install, I simply double-click the file; ASP loads up and installs the plugin. If I already have it installed, ASP asks if I want to upgrade and shows the currently-installed version and the new file version. It then asks if I wnat to restart now or later.
Bibble transplant
claudermilk
Postby Charles+OK on Fri Feb 24, 2012 11:44 am
Not really smart.
cheers
afx
If I manually rename them, it should work?
Charles+OK
Postby afx on Fri Feb 24, 2012 11:47 am
Charles+OK wrote:If I manually rename them, it should work?
Sure...
Unless the ZIP is hosed somehow...
cheers
afx
afx
System_Drive: N/A
Postby Charles+OK on Fri Feb 24, 2012 12:10 pm
Not really smart.
cheers
afx
Sure...
cheers
afx
Tried it and the ASP icon appeared instantly and it installed. Thanks ... thanks... thanks!
Charles+OK
