...and can you please test and tell me whether the donate button does work?
thanks,
tintin
70594.92: ContainerAsset could not get path by ID
70594.96: Container __CATALOG_ROOT__/assets
70594.98: Container __CATALOG_ROOT__/assets/tmp
70594.101: Container __CATALOG_ROOT__/assets/tmp/_markus_
70594.105: Container __CATALOG_ROOT__/assets/tmp/_markus_/foto
70594.108: Container __CATALOG_ROOT__/assets/tmp/_markus_/foto/ASP-Test
70594.110: set sort order ascending
70594.112: Container __CATALOG_ROOT__/assets/tmp/_markus_/foto/ASP-Test/raw_2
70594.338: viewmode: 1
70594.645: Starting import with settings : "<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
<rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
<rdf:Description rdf:about=""
xmlns:bibp="http://www.bibblelabs.com/BibblePrivate/5.0/"
bibp:MoveCopy="2"
bibp:LibraryLoc=""
bibp:LibraryID="2041"
bibp:LibraryUuid="{4efcdfe6-c7df-c045-a4ef-6b60d6cc0306}"
bibp:Organize="0"
bibp:FolderTemplate=""
bibp:Recurse="false"
bibp:RenameOn="false"
bibp:FileTemplate=""
bibp:ImportPath="/tmp/_markus_/foto/ASP-Test/raw_2"
bibp:KeywordList=""
bibp:FolderFilter=""
bibp:QueueName=""
bibp:QueueType="0"
bibp:QueueOnlyNewFiles="false"
bibp:JobName=""
bibp:PresetList=""/>
</rdf:RDF>
</x:xmpmeta>
70594.646: Adding master versions
70594.897: Adding master versions
70594.903: Scanning file "/tmp/_markus_/foto/ASP-Test/raw_2/IMG_0255.CR2"
70594.914: Scanning file "/tmp/_markus_/foto/ASP-Test/raw_2/IMG_1367.CR2"
70594.916: Scanning file "/tmp/_markus_/foto/ASP-Test/raw_2/img_0086.cr2"
70595.550: CAQuest: Hotness Change
70595.550: CAQuest: SettingChanged Event
70595.550: Preset Now
70595.551: ----
70595.665: CAQuest: Settings Change
70595.665: CAQuest: SettingChanged Event
70595.665: Preset Now
70595.665: ----
70595.716: Extracting RAW data: "/tmp/_markus_/foto/ASP-Test/raw_2/img_0086.cr2"
70595.771: Decoding RAW data: "/tmp/_markus_/foto/ASP-Test/raw_2/img_0086.cr2"
70601.44: zText about dialog before 'exec' tintin wrote:...and can you please test and tell me whether the donate button does work?
thanks,
tintin
Hobgoblin wrote:Using Mint 11(Ubuntu) clicking on the Donate Button opens Firefox 10.0.2 but does not pass the URL to the browser.
This is a documented problem with Firefox and Linux.
composite -dissolve 50 -gravity southwest ~/fotos/utils/stamp.png
afx wrote:Hobgoblin wrote:Using Mint 11(Ubuntu) clicking on the Donate Button opens Firefox 10.0.2 but does not pass the URL to the browser.
Really?
Works like a charm on my 11.10 Xubuntu.
cheers
afx
afx wrote:I suspect an interaction with the Windowing system.
Could those that have problems switch to something else for a test?
I use XFCE....
cheersht
afx
Zarastro wrote:Besides the issues with the "about" button which I also have experienced - Fedora 16 64bit here - I'd like to see an option to zText to add embossed texts such as those generated by this ImageMagick code which I run when I convert my pictures for web publication
ogrizzo wrote:Zarastro wrote:Besides the issues with the "about" button which I also have experienced - Fedora 16 64bit here - I'd like to see an option to zText to add embossed texts such as those generated by this ImageMagick code which I run when I convert my pictures for web publication
Doesn't the shadow option render text in a very similar way?
Zarastro wrote:adding it to an image to make a watermark.
